Is 2.16 GhZ slow these days?
Cisco001
Well-Known Member
What have you got at the moment? laptop or desktop?
What is the model number or spec?
What is your budget for new or upgrade PC?
_Kyle_
Well-Known Member
Seeing that an Intel Pentium N350 was serving him fine for his tasks I would really only suggest getting an i3-8100, it seems like a i7 is just a waste of money at this point.
Intel_man
I'm gonna get one anyway. You never know what the future will hold. I need something much faster than this current one.
Err... unless you're planning on video production, gaming with settings cranked to the max for ludicrous frame rates, high thread count processes, you don't need an i7. Nothing you've listed that you currently do warrants an i7. Hell, an i5-8400 is overkill for what you do.
Are you looking at a laptop? Or are you considering getting a desktop?
Laptop
Laquer Head
Well-Known Member
Definitely don't need an i7 for those basic tasks you listed, and if your getting a laptop with an i7 for under $700... I'd question what they skimped out on. Find something with a solid i5, 16GB ram, and a solid state drive... thats all you need!
Never buy a laptop with the mindset of 'pay more now to futureproof'. These days, there is no such thing - laptops are the biggest waste of money going.
Darren
Moderator
That's old news. The current 8th Gen i7 mobile chips are all quads with hyperthreading with the exception of a couple that are hexacores.
Remember that most laptop i7's are dual cores :)
7th gen was 4c/8t too.
and 6th.
https://ark.intel.com/products/97185/Intel-Core-i7-7700HQ-Processor-6M-Cache-up-to-3_80-GHz
https://ark.intel.com/products/88967/Intel-Core-i7-6700HQ-Processor-6M-Cache-up-to-3_50-GHz
Hell I keep checking older and older variants and even most of the 4th gen was 4c/8t.
https://ark.intel.com/products/series/75023/4th-Generation-Intel-Core-i7-Processors
Edit: And even 2nd and 3rd. I've determined @Jiniix you're mostly wrong. :D
https://ark.intel.com/products/series/79666/Legacy-Intel-Core-Processors
Laquer Head
Well-Known Member
After evaluating the situation, I've decided to rescind the 'Like' I gave to @Jiniix earlier.
*leaves*
johnb35
Administrator
Although the I7-7550u along with some others are only dual cores. Which you can still get so you can't say all I7's are quad cores. :cool::p:rolleyes:o_O
Darren
Moderator
Yeah there's a few still but all in all that claim wasn't terribly accurate.
OFF WITH HIS HEAD
Jiniix
Well-Known Member
I went and checked the 8th gen, and yeah, the vast majority is 4c/8t now, with a few 2c/4t and 6c/12t models in the mix.
By far, by miles, the most popular i7 of the 7th gen was the i7-7500U, which was used in just about every sub-$1000 laptop, and it's a dual core. Sure they had higher end skus, but those were for the laptops that 1% of people buy.
I said majority, which I rescind only for the 8th gen :)
Cisco001
Well-Known Member
HP Laptop. HP 15-f272wm.
I wouldn't want to spend more than $700.
If you want to upgrade your existing laptop, you can probably replace the HDD with 240GB SSD.
If you are looking for new laptop, you can probably get something with i5-8250u with 8GB RAM and 256GB SSD
Here are some example
https://www.bestbuy.com/site/acer-1...-drive-obsidian-black/6178420.p?skuId=6178420
https://www.newegg.com/Product/Product.aspx?Item=1TS-000X-00SY9&ignorebbr=1
https://www.newegg.com/Product/Product.aspx?Item=N82E16834269979&ignorebbr=1
Intel_man
All 8th Gen i7 chips are quads and hexa cores. There are no duals under the i7-8xxx naming scheme. Not even the U series.
Laquer Head
Well-Known Member
i7-8500Y, 2 cores, 4 threads, 1.5GHz-4.2GHz boost begs to differ
Not sure that really counts though, correct me if I'm wrong but aren't those 'Y' chips integrated and made for use in laptops/tablets mainly? Hence not a drop in chip / soldered on?
