Can someone advise me
Agent Smith
Well-Known Member
I'd go with the Dell if all you're gonna do is use office Apps, printing and browsing the net. It's cheaper too. You shouldn't be looking at paying more than that for office/home orientated things. There's little difference between both CPUs.
bs1
I just want one foroffice stuff and using the internet but doesn't slow down when i start to add programmes, this is specs for the one ive got now
johnb35
Administrator
The 8100 is a quad core while the 7100 is only a dual core cpu. Unfortunately, I'm finding AMD older A series cpus slower then molasses. Definitely go intel I5 cpu and get an SSD drive, you won't regret it.
bs1
Would you go for a 120GB 2.5" SATA III SSD, which is included in the price, or this 120GB M.2 SATA III SSD for £3 extra
johnb35
Administrator
Unless its an NVME drive there is no speed difference between a sata and an M2. However, you might find 120gb a little too small. General size for an SSD is 250gb. As long as you don't plan on installing a bunch of programs then you should be fine on the 120.
_Pete_
Neither of those are any good for gaming but you are not going to be doing that. Go for the Dell. I say that simply because Dell do a very good home based back up service if they cannot fix your computer over the internet using Dell Connect. Just make sure you back up all your personal files on a regular basis just in case.
Cisco001
Well-Known Member
if you are doing office stuff, you probably best to add a cheap £40 240GB SSD to your existing pc
new pc may not be necessary.
however, if you go for new pc, i recommend you get something with standard micro atx tower.
upgrading or fixing those sff pc in future is a bit of headache.
_Kyle_
Well-Known Member
The second link is not working, the item is no longer available according to the message I get. The Dell ain't that bad though. I would pop a SSD into it, but if you've never used one then you'll be fine.
EDIT: I'm an idiot, the other link probably isn't working because this was linked August 29th... my mistake.
