Is 2.16 GhZ slow these days?
Intel_man
How do I tell how much RAM it can hold max?
Are you referring to the computer that has the N3540 processor you mentioned in this thread?
If I bought a SSD to replace my current Hard Drive, that would involve having to reinstall Windows, correct? Because I don't have the disc. I only have what came preloaded on the laptop.
You can clone the drive. That won't require you to reinstall Windows.
_Kyle_
Well-Known Member
I have a 64-bit operating system with DDR3 RAM. How do I tell how much RAM it can hold max?
Also, my DVD drive is broken. Would it be cheaper to replace that internally, or to get one that plugs into the USB?
Depends on the version, but I can tell you it is at least 8GB. You would have to reinstall a Windows too if you got the SSD, or you could just clone it like Intel_man said.
