WIndows 10 Graphics card for Hp pavilion p6610f
Blabel22
My hp has integrated graphic's and i am planning on buying a graphics card. I want one that can play fortnite.
This is what happened when I launch fortnite.
There is no option to update to a higher version. Online it only shows version 8. not 18. The fortnite recommended requirements showed this.
What is a cheap (less then 100$) graphics card I can buy to use to play fortnite. It can be used or new, I just need a very cheap one.
These are some specs from CPU-Z
Display adapter 0
ID 0x2060080
Name ATI Radeon HD 4200
Board Manufacturer Hewlett-Packard
Codename RS880
Technology 55 nm
Memory size 256 MB
Memory bus width 32 bits
PCI device bus 1 (0x1), device 5 (0x5), function 0 (0x0)
Vendor ID 0x1002 (0x103C)
Model ID 0x9710 (0x2AB1)
Revision ID 0x0
Performance Level 0
Core clock 501.2 MHz
Performance Level 1
Win32_VideoController AdapterRAM = 0x10000000 (268435456)
Win32_VideoController DriverVersion = 8.970.100.9001
Win32_VideoController DriverDate = 01/13/2015
Software
Windows Version Microsoft Windows 10 (10.0) Professional 64-bit (Build 16299)
DirectX Version 12.0
Intel_man
You can find a gtx 750 ti on eBay. I would advise against sellers from China, there has been gpu fakes being sold by some sellers from China lately and as a precaution I would stay away from them.
Also, be advised that that per HP's listing, your computer only has a 250W psu, which should "work", but doesn't technically meet the minimum power supply requirement listed by Nvidia. So if you do end up having performance issues, or crashes when the GPU is under heavy load, you may need to get a more powerful psu.
Blabel22
Can it be a ddr5 graphics card?
beers
Moderator
What are your other PC specs?
750 Ti is pretty much scraping the bottom of the spec sheet but I assume the rest of the PC is very dated as well.
Blabel22
This is everything
CPU-Z TXT Report
Binaries
CPU-Z version 1.87.0.x64
Processors
Number of sockets 1
Number of threads 4
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Core 1 (ID 1)
-- Thread 1 1
-- Core 2 (ID 2)
-- Thread 2 2
-- Core 3 (ID 3)
-- Thread 3 3
Timers
ACPI timer 3.580 MHz
Perf timer 14.318 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name AMD Athlon II X4 635
Codename Propus
Specification AMD Athlon(tm) II X4 635 Processor
Package Socket AM3 (938)
CPUID F.5.3
Extended CPUID 10.5
Brand ID 9
Core Stepping BL-C3
Technology 45 nm
TDP Limit 95.0 Watts
Core Speed 2201.8 MHz
Multiplier x Bus Speed 11.0 x 200.2 MHz
Base frequency (cores) 200.2 MHz
Base frequency (ext.) 200.2 MHz
HT Link speed 2001.7 MHz
Stock frequency 2900 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
Microcode Revision 0x10000C8
L1 Data cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
Max CPUID level 00000005h
Max CPUID ext. level 8000001Bh
Cache descriptor Level 1, I, 64 KB, 1 thread(s)
Cache descriptor Level 1, D, 64 KB, 1 thread(s)
Cache descriptor Level 2, U, 512 KB, 1 thread(s)
FID/VID Control yes
FID range 4.0x - 14.5x
Max VID 1.350 V
# of P-States 4
P-State FID 0xD - VID 0x10 - IDD 19 (14.50x - 1.350 V)
P-State FID 0x6 - VID 0x18 - IDD 14 (11.00x - 1.250 V)
P-State FID 0x1 - VID 0x20 - IDD 13 (8.50x - 1.150 V)
P-State FID 0x100 - VID 0x2A - IDD 9 (4.00x - 1.025 V)
Package Type 0x1
Model 35
String 1 0xA
String 2 0x6
Page 0x0
CmpCap 4
ApicIdCoreSize 4
TDC Limit 76 Amps
Boosted P-States 0
Max non-turbo ratio 14.50x
Max turbo ratio 14.50x
Max CPU COF 29
Core Performance Boost no
P-State 0, FID 0xD - VID 0x10 (14.50x - 1.350 V)
P-State 1, FID 0x6 - VID 0x18 (11.00x - 1.250 V)
P-State 2, FID 0x1 - VID 0x20 (8.50x - 1.150 V)
P-State 3, FID 0x100 - VID 0x2A (4.00x - 1.025 V)
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
PERFEVT 2896.0 MHz
Temperature 0 18 degC (64 degF) (Core #0)
Temperature 1 18 degC (64 degF) (Core #1)
Temperature 2 18 degC (64 degF) (Core #2)
Temperature 3 18 degC (65 degF) (Core #3)
Power 00 70.00 W (Package)
Clock Speed 0 2201.85 MHz (Core #0)
Clock Speed 1 2201.85 MHz (Core #1)
Clock Speed 2 2902.44 MHz (Core #2)
Clock Speed 3 2201.85 MHz (Core #3)
Core 0 max ratio 14.5 (effective 14.5)
Core 1 max ratio 14.5 (effective 14.5)
Core 2 max ratio 14.5 (effective 14.5)
Core 3 max ratio 14.5 (effective 14.5)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x00000005 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00100F53 0x00040800 0x00802009 0x178BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000000
0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00100F53 0x10005236 0x000037FF 0xEFD3FBFF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x4920296D
0x80000003 0x34582049 0x35333620 0x6F725020 0x73736563
0x80000004 0x0000726F 0x00000000 0x00000000 0x00000000
0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140
0x80000006 0x20800000 0x42004200 0x02008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x000001F9
0x80000008 0x00003030 0x00000000 0x00002003 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00000040 0x00000000 0x0000000F
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000
0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000
0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000018
MSR 0xC0010061 0x00000000 0x00000030
MSR 0xC0010062 0x00000000 0x00000000
MSR 0xC0010063 0x00000000 0x00000000
MSR 0xC0010064 0x800001BE 0x3C00200D
MSR 0xC0010065 0x8000018F 0x3C003006
MSR 0xC0010066 0x80000180 0x3C004001
MSR 0xC0010067 0x80000157 0x3C005440
MSR 0xC0010068 0x00000000 0x40000000
MSR 0xC0010058 0x00000000 0xE0000021
MSR 0xC0010071 0x30BA0083 0x3C00200D
MSR 0xC0010015 0x00000000 0x01000010
MSR 0xC001001F 0x42586000 0x00000008
MSR 0xC0010070 0x00000000 0x3C00200D
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x00100F53 0x01040800 0x00802009 0x178BFBFF
MSR 0x0000001B 0x00000000 0xFEE00800
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x00100F53 0x02040800 0x00802009 0x178BFBFF
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 3, Thread ID 0
CPUID
0x00000001 0x00100F53 0x03040800 0x00802009 0x178BFBFF
BIOS
UEFI No
AMD AGESA V3.7.0.1
Chipset
Northbridge AMD 785G rev. 00
Southbridge AMD SB700 rev. 00
Memory Type DDR3
Memory Size 8 GBytes
Channels Dual, (Unganged)
Memory Frequency 667.2 MHz (3:10)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Bank Cycle Time (tRC) 33
Command Rate (CR) 2T
Uncore Frequency 2001.7 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Elpida (7F7FFE0000000000000000)
Size 2048 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number EBJ21UE8BDF0-DJ-F
Serial number 5D0E118C
Manufacturing date Week 06/Year 10
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-17-23 @ 457 MHz
JEDEC #2 7.0-7-7-20-27 @ 533 MHz
JEDEC #3 8.0-8-8-22-30 @ 609 MHz
JEDEC #4 9.0-9-9-24-33 @ 666 MHz
DIMM # 2
SMBus address 0x51
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Serial number 650E118C
Number of banks 8
EPP no
XMP no
AMP no
DIMM # 3
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Serial number 056D0D54
Manufacturing date Week 15/Year 10
Number of banks 8
EPP no
XMP no
AMP no
DIMM # 4
SMBus address 0x53
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Serial number 246D0D57
Number of banks 8
EPP no
XMP no
AMP no
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 3C 00
10 69 78 69 30 69 11 20 89 70 03 3C 3C 00 F0 83 81
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 02 FE 4C 10 06 5D 0E 11 8C AB A7
80 45 42 4A 32 31 55 45 38 42 44 46 30 2D 44 4A 2D
90 46 20 30 20 02 FE 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM # 2
SPD registers
70 00 00 00 00 00 02 FE 4C 10 06 65 0E 11 8C AB A7
DIMM # 3
SPD registers
70 00 00 00 00 00 02 FE 4C 10 15 05 6D 0D 54 AB A7
90 46 20 30 20 02 FE 00 00 00 00 00 00 00 00 34 05
A0 00 00 00 00 00 00 00 00 00 00 00 00 81 02 01 11
DIMM # 4
SPD registers
70 00 00 00 00 00 02 FE 4C 10 15 24 6D 0D 57 AB A7
Monitoring
Mainboard Model 2AB1 (0x000000E6 - 0x00002688)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8721
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8721
LPCIO Revision ID 0x1
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 21 01 08 00 00 FF 00 00 10 00 00 43 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0E 80 0E 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0E80
Hardware Monitors
Hardware monitor ITE IT8721
Voltage 1 5.06 Volts [0xEC] (+5V)
Voltage 2 2.22 Volts [0xB9] (CPU VCORE)
Voltage 3 1.66 Volts [0x8A] (VIN3)
Voltage 4 2.22 Volts [0xB9] (VIN4)
Voltage 5 2.77 Volts [0xB9] (+3.3V)
Voltage 6 2.22 Volts [0xB9] (VIN6)
Voltage 7 1.64 Volts [0x89] (VIN7)
Temperature 0 19 degC (66 degF) [0x13] (CPU)
Temperature 1 29 degC (84 degF) [0x1D] (Mainboard)
Fan 0 1795 RPM [0x178] (CPU)
Fan 1 938 RPM [0x2D0] (FANIN1)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 19 10 FD 03 00 00 00 00 00 80 58 0F 07 77 CF 00
10 4E 8F 7D 33 D0 80 80 00 01 02 00 76 07 06 06 06
20 FF EC B9 8A B9 B9 B9 89 86 13 1D 80 80 FF 3F 3F
30 6D A7 FE B5 39 8A 5D DF 9C 0B 36 1D 5C 0F BD DB
40 BF 1E CF 79 58 44 5F 40 AD 6A D4 00 FF FF FF FF
50 FF 03 7F 7F 7F 40 F1 00 90 00 37 12 60 00 00 00
60 81 2E 46 4D 15 08 00 FF 81 2E 46 4D 15 08 00 FF
70 7F 7F 7F 80 00 00 00 FF FF FF FF FF FF FF FF FF
80 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 02 3E
90 42 39 25 00 43 29 45 00 FF FF FF FF FF FF FF FF
A0 A0 DF DF DF DF DF DF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor D3D
Hardware monitor ATI I/O
Clock Speed 0 196.90 MHz [0xC4] (Graphics)
Hardware monitor AMD ADL
Clock Speed 1 667.00 MHz [0xC4] (Memory)
PCI Devices
Register space PCI Express, base address = 0x0E0000000
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x9601
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2AB1
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class HyperTransport
Caps offset 0xC4
Caps revision 3.00
Interface type Slave/Primary
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 2000 MHz
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 200 MHz
PCI capability
Caps offset 0x54
Interface type Clumping
PCI capability
Caps offset 0x40
Interface type Retry Mode
PCI capability
Caps offset 0x9C
Interface type Gen3
PCI capability
Caps offset 0xF8
Interface type Power Management
PCI registers
00 22 10 01 96 06 00 30 22 00 00 00 06 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 3C 10 B1 2A
30 00 00 00 00 C4 00 00 00 00 00 00 00 00 00 00 00
40 08 9C 00 C0 C1 00 00 00 22 00 00 00 42 20 05 00
50 3C 10 B1 2A 08 40 00 90 08 10 05 00 08 00 05 00
60 3C 00 00 00 00 00 00 00 00 02 20 00 0B C0 86 85
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20
80 00 00 00 00 10 00 00 03 20 C0 00 00 33 26 00 00
90 00 00 00 D0 7F 00 00 00 00 00 00 00 08 F8 7C D0
A0 26 00 66 00 00 00 00 80 00 00 00 00 79 01 C0 07
C0 00 00 00 80 08 54 80 01 20 00 11 11 D0 00 00 00
D0 60 0B 75 1E 02 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 0D 00 00 00 64 40 05 00
F0 00 00 00 00 00 80 80 00 08 00 00 E0 00 00 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x9602
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x40
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x44
Interface type MSI Mapping
PCI capability
Caps class Subsystem Vendor
Caps offset 0xB0
SubVendor ID 0x1022
SubSystem ID 0x9602
PCI registers
00 22 10 02 96 07 01 30 02 00 00 04 06 00 40 01 00
10 00 00 00 00 00 00 00 00 00 01 01 40 D1 D1 20 02
20 80 FE 90 FE 01 D0 F1 DF 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 1A 00
40 00 00 00 00 08 B0 03 A8 00 00 00 00 22 10 02 96
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 0D 00 00 00 22 10 02 96 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x9605
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x0A
Int. Pin 0x01
PCI capability
Caps class Power Management
Caps offset 0x50
Caps version 1.2
PCI capability
Caps class PCI Express
Caps offset 0x58
Device type Root Port of PCI-E Root Complex
Port 2
Version 2.0
Physical slot #0
Presence detect yes
Link width 1x (max 1x)
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0xA0
PCI capability
Caps offset 0xB0
SubVendor ID 0x103C
SubSystem ID 0x2AB1
PCI capability
Caps offset 0xB8
Extended capabilities
Caps class Vendor Specific
Caps offset 0x100
Vendor ID 1
Size 16
Caps class Virtual Channel
Caps offset 0x110
PCI registers
00 22 10 05 96 06 05 10 00 00 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 00 F1 01 00 20
20 A0 FE A0 FE F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 0A 01 07 00
50 01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00
60 10 08 00 00 12 0C 30 02 40 00 11 70 80 0C 2C 00
70 00 00 48 01 00 00 01 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
A0 05 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 0D B8 00 00 3C 10 B1 2A 08 00 03 A8 00 00 00 00
E0 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00
100 0B 00 01 11 01 00 01 01 00 00 00 00 00 00 00 00
110 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
120 01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00
130 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x9609
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x0B
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 1
Version 2.0
Physical slot #1
Presence detect yes
PCI capability
Caps offset 0xA0
PCI capability
Caps offset 0xB0
SubVendor ID 0x103C
SubSystem ID 0x2AB1
PCI capability
Caps offset 0xB8
Caps offset 0x100
Vendor ID 1
Size 16
Caps offset 0x110
PCI registers
00 22 10 09 96 07 05 10 00 00 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 03 03 00 E1 E1 00 20
20 B0 FE B0 FE F1 FD F1 FD 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 0B 01 07 00
50 01 58 03 C8 00 01 00 00 10 A0 42 01 20 80 00 00
60 10 08 00 00 12 0C 30 01 40 00 11 70 80 0C 54 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Serial ATA Controller
Location bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4391
Revision ID 0x00
PI 0x01
SubClass 0x06
BaseClass 0x01
Cache Line 0x10
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x0000C000
Address 1 (port) 0x0000B000
Address 2 (port) 0x0000A000
Address 3 (port) 0x00009000
Address 4 (port) 0x00008000
Address 5 (memory) 0xFE7FFC00
Subvendor ID 0x103C
Subsystem ID 0x2AB1
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x60
Caps version 1.1
PCI capability
Caps class 0x12
Caps offset 0x70
PCI registers
00 02 10 91 43 07 01 30 02 00 01 06 01 10 40 00 00
10 01 C0 00 00 01 B0 00 00 01 A0 00 00 01 90 00 00
20 01 80 00 00 00 FC 7F FE 00 00 00 00 3C 10 B1 2A
30 00 00 00 00 60 00 00 00 00 00 00 00 16 01 00 00
40 10 00 B0 00 01 00 10 00 C0 BF 00 00 00 00 00 00
50 05 70 86 00 00 00 00 00 00 00 00 00 00 00 00 00
60 01 70 22 00 00 00 00 00 00 00 00 00 00 00 00 00
70 12 00 10 00 0F 00 00 00 38 02 00 00 00 00 00 00
80 00 00 00 00 06 00 00 2C 16 A0 B4 01 16 A0 B4 01
90 16 A0 B4 01 16 A0 B4 01 16 A0 B4 01 D8 A0 B4 01
A0 7A A0 7A A0 DB A0 DA A0 DA A0 FC A0 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00
E0 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description USB Controller (OHCI)
Location bus 0 (0x00), device 18 (0x12), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4397
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x40
Header 0x80
PCI header
Address 0 (memory) 0xFE7FE000
Subvendor ID 0x103C
Subsystem ID 0x2AB1
Int. Line 0x10
Int. Pin 0x01
PCI registers
00 02 10 97 43 06 01 A0 02 00 10 03 0C 10 40 80 00
10 00 E0 7F FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 10 01 00 00
40 80 03 00 00 11 00 00 00 00 00 00 00 00 00 00 00
50 40 13 03 F6 00 00 00 00 FF FF FF FF 00 00 00 00
70 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 18 (0x12), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0x4398
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFE7FD000
Subvendor ID 0x103C
Subsystem ID 0x2AB1
Int. Line 0x10
Int. Pin 0x01
PCI registers
00 02 10 98 43 16 01 A0 02 00 10 03 0C 10 40 00 00
10 00 D0 7F FE 00 00 00 00 00 00 00 00 00 00 00 00
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 18 (0x12), function 2 (0x02)
Common header
Vendor ID 0x1002
Model ID 0x4396
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFE7FF800
Subvendor ID 0x103C
Subsystem ID 0x2AB1
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0xC0
Caps version 1.1
PCI capability
Caps class Debug Port
Caps offset 0xE4
PCI registers
00 02 10 96 43 16 01 B0 02 00 20 03 0C 10 40 00 00
10 00 F8 7F FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 C0 00 00 00 00 00 00 00 11 02 00 00
50 D8 01 9E 82 00 00 00 00 00 00 00 00 00 00 00 00
60 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00
C0 01 E4 02 7E 00 00 40 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 0A 00 E0 20 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 19 (0x13), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4397
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x40
Header 0x80
PCI header
Address 0 (memory) 0xFE7FC000
Subvendor ID 0x103C
Subsystem ID 0x2AB1
Int. Line 0x12
Int. Pin 0x01
PCI registers
10 00 C0 7F FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00
Location bus 0 (0x00), device 19 (0x13), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0x4398
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFE7F7000
Subvendor ID 0x103C
Subsystem ID 0x2AB1
Int. Line 0x12
Int. Pin 0x01
PCI registers
10 00 70 7F FE 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 19 (0x13), function 2 (0x02)
Common header
Vendor ID 0x1002
Model ID 0x4396
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFE7FF400
Subvendor ID 0x103C
Subsystem ID 0x2AB1
Int. Line 0x13
Int. Pin 0x02
PCI capability
Caps offset 0xC0
Caps version 1.1
PCI capability
Caps offset 0xE4
PCI registers
10 00 F4 7F FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 C0 00 00 00 00 00 00 00 13 02 00 00
Description SMBus Controller
Location bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4385
Revision ID 0x3C
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2AB1
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0xB0
PCI registers
00 02 10 85 43 03 04 30 D2 3C 00 05 0C 00 00 80 00
30 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00
40 44 EB 00 FD 00 00 00 00 0F FF 00 00 00 00 00 C0
50 F0 01 B0 0A F0 0F F0 0F 21 0B F0 0F 80 00 10 00
60 01 00 24 20 BF FC 9E 03 7F 90 00 00 20 00 00 00
70 00 00 00 00 08 00 C0 FE FF 6E 00 00 00 00 E0 06
80 F8 0A F0 0F 00 00 00 00 00 00 00 00 00 00 00 00
90 01 0B 00 00 F9 CE FF 00 00 00 00 00 00 00 00 00
A0 00 00 FF FF 7F FF F0 09 00 FF 28 02 06 41 68 18
B0 08 00 02 A8 00 00 D0 FE 00 00 00 00 F0 0F 08 1A
C0 09 60 E0 DF 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 20 99 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 D8 0C 00 00 00 00 44 00 00 00 00 00 02 00 30 04
Description Multimedia device
Location bus 0 (0x00), device 20 (0x14), function 2 (0x02)
Common header
Vendor ID 0x1002
Model ID 0x4383
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFE7F0000
Subvendor ID 0x103C
Subsystem ID 0x2AB1
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI registers
00 02 10 83 43 06 00 10 04 00 00 03 04 10 40 00 00
10 04 00 7F FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
40 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00
50 01 00 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 20 (0x14), function 3 (0x03)
Common header
Vendor ID 0x1002
Model ID 0x439D
Revision ID 0x00
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2AB1
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 02 10 9D 43 0F 00 20 02 00 00 01 06 00 00 80 00
40 04 00 00 00 D5 FF 03 FF 17 FF 60 00 00 00 00 00
60 00 00 00 00 00 0E 00 00 0E 00 0F 00 B0 FF FF FF
70 67 45 23 00 00 00 00 00 1C 00 00 00 05 0A 00 00
80 08 00 03 A8 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 08 01 00 00 00
A0 02 00 C1 FE 2F 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 E9 F2 FF 00 00
C0 00 00 00 00 00 00 08 00 F7 FF FF FF 00 00 00 78
D0 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 0C
Location bus 0 (0x00), device 20 (0x14), function 4 (0x04)
Common header
Vendor ID 0x1002
Model ID 0x4384
Revision ID 0x00
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x40
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 02 10 84 43 07 05 A0 02 00 01 04 06 00 40 81 00
10 00 00 00 00 00 00 00 00 00 04 04 40 F0 00 80 22
20 F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00
40 26 00 3C FF 00 00 00 00 0C 0F 3D D1 00 01 00 00
50 01 00 00 00 08 00 03 A8 00 00 00 00 85 00 FF FF
60 CA 0E 17 00 BA D8 10 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 02 06
E0 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1200
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x80
Caps revision 3.00
Interface type Host/Secondary
Device number 0
PCI registers
00 22 10 00 12 00 00 10 00 00 00 00 06 00 00 80 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 01 02 04 00 01 02 04 00 01 02 04 00 01 02 04 00
50 01 02 04 00 01 02 04 00 01 02 04 00 01 02 04 00
60 00 00 03 00 E0 00 00 00 20 A8 2F 01 20 F8 00 00
80 08 00 01 21 20 20 11 11 60 0B F5 8F 13 00 00 00
90 D0 02 85 80 00 00 00 00 07 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1201
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 01 12 00 00 00 00 00 00 00 06 00 00 80 00
40 03 00 00 00 00 00 2F 02 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 03 0A 00 00 00 0B 00 00
A0 03 00 D0 00 80 FF EF 00 03 00 F0 00 00 7F FE 00
B0 03 80 FE 00 80 9F FE 00 03 A0 FE 00 00 EF FF 00
C0 13 10 00 00 00 F0 FF 00 00 00 00 00 00 00 00 00
E0 03 00 00 07 00 00 00 00 00 00 00 00 00 00 00 00
F0 03 30 00 D0 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x1202
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 02 12 00 00 00 00 00 00 00 06 00 00 80 00
40 01 00 00 00 09 01 00 00 01 02 00 00 09 03 00 00
60 E0 3C F8 00 E0 3C F8 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 06 00 08 0E 28 04 11 18
80 55 00 00 00 D4 0A 24 00 45 96 16 00 66 B9 22 01
90 00 00 01 00 0D 89 58 3F 07 03 00 80 00 00 00 00
A0 00 02 00 00 00 00 00 00 40 00 00 00 00 00 00 00
B0 7C 10 DE E8 AD 00 00 00 1F 84 24 83 F1 20 19 2A
D0 D5 B7 02 02 0D 40 AC 3F B3 87 86 8E AC E7 CB 81
E0 7A 7E EF BE 2D 4D FB BF 06 1A 80 2E 74 FA 0B 10
Location bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x1203
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Secure Device
Caps offset 0xF0
PCI registers
00 22 10 03 12 00 00 10 00 00 00 00 06 00 00 80 00
30 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00
40 FF FF FF 3F 5C 00 B0 4A 00 00 00 00 00 00 00 00
50 00 00 00 00 6F 15 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 04 00 24 34 00 00 00 30 51 80 01 60
70 51 11 32 60 01 01 98 00 14 0C 20 00 0D 08 07 00
80 81 E6 0B E6 E6 41 E6 01 08 00 00 00 00 60 58 42
90 00 00 00 00 0F 0B 00 00 D0 4D 2E ED 00 00 00 00
A0 00 08 02 B0 EF 0F 68 12 4C 05 04 00 00 00 00 00
D0 00 00 00 00 26 0F 81 C8 16 18 2A 03 2A 53 27 00
E0 00 00 00 00 30 1A 40 1C 59 7F 07 00 00 00 00 00
F0 0F 00 10 00 00 00 00 00 00 00 00 00 53 0F 10 00
Location bus 0 (0x00), device 24 (0x18), function 4 (0x04)
Common header
Vendor ID 0x1022
Model ID 0x1204
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 04 12 00 00 00 00 00 00 00 06 00 00 80 00
Description VGA Controller
Location bus 1 (0x01), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x9710
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xD0000000
Address 1 (port) 0x0000D000
Address 2 (memory) 0xFE8F0000
Address 5 (memory) 0xFE900000
Subvendor ID 0x103C
Subsystem ID 0x2AB1
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0xA0
PCI registers
00 02 10 10 97 07 05 10 00 00 00 00 03 10 00 80 00
10 08 00 00 D0 01 D0 00 00 00 00 8F FE 00 00 00 00
20 00 00 00 00 00 00 90 FE 00 00 00 00 3C 10 B1 2A
30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 3C 10 B1 2A
50 01 A0 03 06 00 00 00 00 10 A0 12 00 A0 8F 00 00
60 10 08 0A 00 01 0D 00 00 00 00 01 11 00 00 00 00
80 00 00 00 00 00 00 00 00 01 00 01 00 00 00 00 00
A0 05 00 81 00 0C F0 E0 FE 00 00 00 00 81 49 00 00
Description Network Controller
Location bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1814
Model ID 0x3090
Revision ID 0x00
PI 0x00
SubClass 0x80
BaseClass 0x02
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFEAF0000
Subvendor ID 0x11AD
Subsystem ID 0x6632
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.2
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x70
Device type PCI-E Endpoint Device
Port 0
Version 2.0
Caps class Advanced Error Reporting
Caps offset 0x100
Caps class Device Serial Number
Caps offset 0x140
PCI registers
00 14 18 90 30 06 05 10 00 00 00 80 02 10 00 00 00
10 00 00 AF FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 AD 11 32 66
30 00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
40 01 50 C3 01 00 00 00 00 00 00 00 00 00 00 00 00
50 05 70 CB 00 0C F0 E0 FE 00 00 00 00 40 49 00 00
70 10 00 02 00 C0 8E 64 00 00 20 09 00 11 3C 07 00
80 40 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 10 00 00 00 10 00 00 00 00 00 00 00
100 01 00 01 14 00 00 00 00 00 00 00 00 30 20 06 00
110 00 20 00 00 C1 31 00 00 A0 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Ethernet Controller
Location bus 3 (0x03), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8136
Revision ID 0x05
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000E800
Address 2 (memory) 0xFEBFF000
Address 4 (memory) 0xFDFFC000
Subvendor ID 0x103C
Subsystem ID 0x2AB1
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.2
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x70
Port 0
Version 2.0
PCI capability
Caps class MSI-X
Caps offset 0xB0
PCI capability
Caps class Virtual Product Data
Caps offset 0xD0
Caps offset 0x100
Caps offset 0x140
Caps offset 0x160
PCI registers
00 EC 10 36 81 07 05 10 00 05 00 00 02 10 00 00 00
10 01 E8 00 00 00 00 00 00 04 F0 BF FE 00 00 00 00
20 0C C0 FF FD 00 00 00 00 00 00 00 00 3C 10 B1 2A
40 01 50 C3 FF 08 01 00 00 00 00 00 00 00 00 00 00
50 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 B0 02 02 C0 8C 64 00 00 50 19 00 11 3C 07 00
B0 11 D0 03 80 04 00 00 00 04 08 00 00 00 00 00 00
D0 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 01 00 01 14 00 00 00 00 00 00 10 00 30 20 06 00
110 01 20 00 00 00 20 00 00 A0 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor American Megatrends Inc.
version 6.02
date 07/21/2010
ROM size 1024 KB
DMI System Information
manufacturer Hewlett-Packard
product p6610f
version unknown
serial MXX0340DKH
UUID {9006A2B3-4A89-7FA3-2220-8DF6CB0DD33D}
SKU BM417AA#ABA
family 103C_53316J G=D
DMI Baseboard
vendor FOXCONN
model 2AB1
revision DVT
serial unknown
DMI System Enclosure
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer AMD
model AMD Athlon(tm) II X4 635 Processor
clock speed 2900.0 MHz
FSB speed 200.0 MHz
multiplier 14.5x
DMI Extension Slot
designation PCI-E x16
type A5
populated no
DMI Extension Slot
designation MINI PCI-E x1
type A5
populated yes
DMI Extension Slot
type A5
populated no
DMI Extension Slot
type A5
populated no
DMI Extension Slot
type A5
populated no
DMI OEM Strings
string[0] FBYTE#2U2V333E3K3N3Q3R3V3X3m3u464k5E5c5u5x676J6S6b7B.E3;BUILDID#
string[1] 10NAFMRW603#SABA#DABA;
string[2]
string[3]
string[4]
string[5]
string[6]
string[7]
string[8]
string[9]
string[10]
string[11]
string[12]
string[13]
string[14]
string[15]
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 16 GB
max# of devices 4
DMI Memory Device
designation DIMM1
format DIMM
type DDR3
total width 64 bits
data width 64 bits
size 2 GB
DMI Memory Device
designation DIMM2
format DIMM
type DDR3
total width 64 bits
data width 64 bits
size 2 GB
DMI Memory Device
designation DIMM3
format DIMM
type DDR3
total width 64 bits
data width 64 bits
size 2 GB
DMI Memory Device
designation DIMM4
format DIMM
type DDR3
total width 64 bits
data width 64 bits
size 2 GB
Storage
Drive 0
Name WDC WD2500AAKX-603CA0
Revision 18.01H18
Serial WD-WMAYW0882740
Capacity 232.9 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 7200 RPM
Features SMART
Volume m:\, 232.3 GBytes (88.6 percent available)
Drive 1
Name ST3160815AS
Revision 4.ADA
Serial 5RX59ZC9
Capacity 149.0 GB
Type Fixed
Bus Type SATA (11)
Features SMART
Volume c:\, 149.0 GBytes (85.7 percent available)
USB Devices
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x046D, product=0xC52B
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x046D, product=0xC513
USB Device USB Mass Storage Device, class=0x00, subclass=0x00, vendor=0x058F, product=0x6362
Graphics
Number of adapters 1
Graphic APIs
API D3D
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
ID 0x2060080
Codename RS880
Technology 55 nm
Memory size 256 MB
Revision ID 0x0
Performance Level 0
Performance Level 1
Software
Register Spaces
Register space PCI
Register space PCI #2
Register space class = 0x12
Register space SMBus, base address = 0x0B00
Register space LPC, base address = 0x02E
Register space LPC, base address = 0x0CD0
Intel_man
Should be fine. Make an offer, just don't low ball. Check out some sold ebay listings for a gtx 750 ti and make an offer close to those numbers.
Intel_man
Yea, if the seller's offering a best offer, don't see why you shouldn't try offering him slightly below what he's asking.
