Windows 7 USB slots on PC connect and disconnect on random intervals
Ma-dazz
I got 2 fairly old (I'd say around 8 years old) USB slots on the front of my PC that don't function normally lately. Most of the time, mostly when I insert a big external HDD, they are connected and disconnected from my PC for even 10 times in half a minute, in which case I remove them to prevent any damage to the HDD. I tried with some USB slots on the back, connected via a USB hub, and it was even worse, the one I connected was making clicking sounds so I got it out immediately. None of my external HDDs or flash drives have a problem, in fact they work completely normally as they should (but only half the time when they are connected to this PC) and I have almost never had problems like this in my Ubuntu OS (dual-boot on the same PC) during the same time-frame. Moreover, the external HDD that showed the most problems was a brand new one which I used about 3 times. Now I'm completely abstaining from connecting anything but flash drives on my PC which is a big nuisance.
What's at fault here? Will I need to make a new purchase?
johnb35
Administrator
Sounds like something is up with the USB ports as well. I would bet a new case perhaps or could be a motherboard USB issue or its grounding out somewhere. Need to figure it out though.
Ma-dazz
If it's clicking it's dead. RMA it.
It's not dead, I tested it and it still works. Again, this is not the only external HDD that has had these problems on it (by "these problems" I mean weird but otherwise not permanently damaging behavior).
It's a fairly new motherboard, less than 2 years old. Do USB ports like this come only with new cases? Can I buy them separately? What's the search term for these?
johnb35
Administrator
That don't mean anything. Onboard chips can die at any time. The case USB's could be shorting out because of a metal piece inside of them or for some other reason. If you are having the same issue with the USB's on the back of the motherboard then its definitely a motherboard issue.
Ma-dazz
The thing is, I didn't directly use the USB ports on the back since my external HDD's cable is too short, so I used an old USB hub to facilitate connectivity. That's how it started clicking and I almost immediately removed it. I could assume it was the hub having the problem, so I didn't bother again. Otherwise, the mouse, keyboard and printer that I have connected on the back work perfectly. So I still can't be sure if it's the motherboard that has the problem or just that random USB hub I've seen laying around and used only once.
