RX 570
volcano1
i am planning on upgrading from an asus r7 360 to a rx 570 but am deciding between an asus 4gb or an msi 8gb. i have a ASRock FM2A88X Extreme4+ motherboard and a amd a8 7600 processor. i am not sure if my board will support these newer cards.
I'm not sure the A8 7600 is capable of pushing the RX 570 at all.
Are you planning on upgrading anything else?
Your board will be okay, in cpu intense games your system will bottleneck a bit, but you can always upgrade that later. 570 are pretty inexpensive now, the 8G version will have some more longevity to it.
What power supply do you have?
CORSAIR CSM Series CS450M 450W i also have 16gb of ddr3 1866 ram. i am kinda leaning to asus version because of software. i also dont really want to do a new build either. the a8 7600 has two TDP setting in the bios a 45 watt mode and a 65 watt mode i currently have it set to auto should i kick it into 65 watt mode or should i upgrade.
