JohnJSal
Hi all. I think I've decided on an upgrade to my GPU. At least, I've decided on the model. But there are so many versions that my head spins. I'm looking at these below. Can someone explain to me what's so different about them, or if any are better than the others?
Also, how can I be sure my choice is compatible with my motherboard?
https://www.newegg.com/Product/Product.aspx?Item=N82E16814932130
https://www.newegg.com/Product/Product.aspx?Item=N82E16814932131
https://www.newegg.com/Product/Product.aspx?Item=N82E16814487430
https://www.amazon.com/EVGA-GeForce...=1660+ti&qid=1557888824&s=gateway&sr=8-4&th=1
That last link actually has four different variants of the card. The only noticeable difference is that some have two fans and some have one, but otherwise I have no idea how to pick!
Thanks!
Thanks!
