I put Adata SX6000 Lite into my 3rd Gen Carbon and got 2103 Error. Some Lenovo Forum folks share strange method of making it work, but I would rather buy another compatible SSD. Which one could you recommend?
Seems that this laptop is only compatible with M.2 SATA. At least Patriot unit, I put there works just fine
Thank you, I will update BIOS. PCIe should be much fasterIt likely boils down to a simple BIOS update as other forums have stated and this isn't abnormal.
