Monitor suggestions?
UserJ
Hey everybody so I'm pretty close to getting my first computer and I need a monitor to go with it of course. My budget is $75-150 max but I hope to keep it closer to $100 also I'll be playing a lot of video games/youtube/schoolwork with it. If it helps heres my (most likely) build below, for the custom it's going to be the Ryzen 3300X and matX B550. Also I would prefer the screen not to be too small, as big as my budget provides. Thanks so much guys!
Also, I'll most likely have a different tower. Thanks!
You can get a 24" Asus 1080P monitor for about $120-125. Highly recommend Asus.
This is the only one I found that fits that criteria and its $145 and out of stock at newegg, do you happen to know where I can get one? Preferably amazon or newegg. Also my I ask why you prefer Asus over other brands like Panasonic, Acer, Sceptre etc? Thanks so much sir!
They aren't listed as "gaming" monitors but you want to keep it within your budget.
https://www.newegg.com/asus-vs248h-p-24/p/N82E16824236153?Item=N82E16824236153&quicklink=true
https://www.newegg.com/asus-ve248q-24/p/N82E16824236154?Item=N82E16824236154&quicklink=true
I used to buy nothing but Acer, but after getting a 27" Asus, i'll never go back.
Those are virtually perfect! My only question is the hz it doesnt say and I want at least a 75hz. I imagine they are but im unsure. Thanks!
