Windows 10 crashing
johnnyb58
I’ve been getting the dreaded blue screen and shutting done every day for a week now. It always happens when I’m reading the news on Chrome. The only thing that has changed is that I activated the Malwarebytes free trial, but I’m not sure it’s related unless it’s stopping something suspicious. Should I remove Malwarebytes ?
Yes! You should remove malwarebytes! Its not good anymore.. and misses out on detecting many malwares..
Try https://home.sophos.com instead..
But have you tried to use your "reliability monitor"? https://lifehacker.com/how-to-troubleshoot-windows-10-with-reliability-monitor-1745624446
Try using this tool to find out WHAT causes these bluescreens (that actuallt is errormessages)
If you cannot fix the issues your self, backup your files that you like to keep (to OneDrive or a USB-disk)
Then get the SUPERSIMPLE Windows installation guide from https://WinGuider.se/en
they have a guide that hows you step by step how to reset your PC the correct way (so you avoid these problems from now on)
You have no idea what you are talking about. Your whole reply is irrelevant to the problem he is having. The free version of Malwarebytes is only an on demand scanner, meaning will only detect things when you run it yourself. How about we find out what is causing the real reason behind the blue screens?
Download the run this so we can find out what is really going on with your system.
Download BlueScreenView
No installation required.
Unzip downloaded file and double click on BlueScreenView.exe file to run the program.
When scanning is done, go Edit>Select All.
Go File>Save Selected Items, and save the report as BSOD.txt.
Open BSOD.txt in Notepad, copy all content, and paste it into your next reply.
Dump File : 051820-42312-01.dmp
Crash Time : 5/18/2020 7:41:57 PM
Bug Check String : KMODE_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x0000001e
Parameter 1 : ffffffff`c0000005
Parameter 2 : fffff802`294efe37
Parameter 3 : ffff9782`2e170108
Parameter 4 : fffff802`30a80930
Caused By Driver : mwac.sys
Caused By Address : mwac.sys+fe37
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+1c2390
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\051820-42312-01.dmp
Processors Count : 6
Major Version : 15
Minor Version : 18362
Dump File Size : 977,872
Dump File Time : 5/18/2020 7:43:19 PM
Dump File : 051820-40218-01.dmp
Crash Time : 5/18/2020 2:34:37 PM
Parameter 2 : fffff801`319efe37
Parameter 3 : ffff8000`a45f5108
Parameter 4 : ffff8f00`11cb8930
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\051820-40218-01.dmp
Major Version : 15
Dump File Size : 1,041,388
Dump File Time : 5/18/2020 4:08:46 PM
Dump File : 051620-42578-01.dmp
Crash Time : 5/16/2020 9:33:04 PM
Parameter 2 : fffff801`06c8fe37
Parameter 3 : fffffb05`fdd50108
Parameter 4 : ffffbc80`da4b6930
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\051620-42578-01.dmp
Major Version : 15
Dump File Size : 979,928
Dump File Time : 5/16/2020 9:34:26 PM
Dump File : 051520-39750-01.dmp
Crash Time : 5/15/2020 7:02:53 PM
Bug Check String : DRIVER_POWER_STATE_FAILURE
Bug Check Code : 0x0000009f
Parameter 1 : 00000000`00000004
Parameter 2 : 00000000`0000012c
Parameter 3 : ffffb88f`4b307040
Parameter 4 : ffffde8e`79a68c30
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+1c2390
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\051520-39750-01.dmp
Major Version : 15
Dump File Size : 1,118,800
Dump File Time : 5/15/2020 7:04:10 PM
Dump File : 051420-39718-01.dmp
Crash Time : 5/14/2020 6:46:05 PM
Bug Check String : DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x000000d1
Parameter 1 : 00000216`e34db000
Parameter 2 : 00000000`00000002
Parameter 3 : 00000000`00000000
Parameter 4 : fffff800`0bf9fdce
Caused By Address : mwac.sys+fdce
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\051420-39718-01.dmp
Major Version : 15
Dump File Size : 1,106,426
Dump File Time : 5/14/2020 6:47:24 PM
Dump File : 051420-52171-01.dmp
Crash Time : 5/14/2020 1:15:22 PM
Parameter 2 : fffff806`1377fe37
Parameter 3 : fffffd89`76f85108
Parameter 4 : fffff806`1a480930
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\051420-52171-01.dmp
Major Version : 15
Dump File Size : 953,310
Dump File Time : 5/14/2020 1:16:52 PM
Dump File : 051220-41531-01.dmp
Crash Time : 5/12/2020 1:20:09 PM
Parameter 2 : fffff805`4850fe37
Parameter 3 : ffffd100`5453f108
Parameter 4 : ffff9580`d4b7e930
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\051220-41531-01.dmp
Major Version : 15
Dump File Size : 1,047,902
Dump File Time : 5/12/2020 1:21:28 PM
Dump File : 051120-38468-01.dmp
Crash Time : 5/11/2020 12:09:05 PM
Parameter 2 : fffff805`133dfdce
Parameter 3 : fffff88e`c7082108
Parameter 4 : ffff8a00`0e899930
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\051120-38468-01.dmp
Major Version : 15
Dump File Size : 1,069,776
Dump File Time : 5/11/2020 12:58:06 PM
Dump File : 051020-47328-01.dmp
Crash Time : 5/10/2020 9:12:25 AM
Parameter 1 : 00000000`00100000
Parameter 4 : fffff800`3ab3fdce
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\051020-47328-01.dmp
Major Version : 15
Dump File Size : 684,888
Dump File Time : 5/10/2020 9:13:49 AM
Dump File : 040520-36250-01.dmp
Crash Time : 4/5/2020 8:35:19 PM
Parameter 3 : ffff9209`a7fb1040
Parameter 4 : ffffa500`244298e0
Caused By Address : ntoskrnl.exe+1c2380
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+1c2380
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\040520-36250-01.dmp
Major Version : 15
Dump File Size : 970,918
Dump File Time : 4/5/2020 8:36:38 PM
Dump File : 040220-36671-01.dmp
Crash Time : 4/2/2020 11:15:39 PM
Parameter 3 : ffffe303`e96092c0
Parameter 4 : fffff805`5d06b8e0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\040220-36671-01.dmp
Major Version : 15
Dump File Size : 1,041,818
Dump File Time : 4/2/2020 11:16:54 PM
Dump File : 040120-36281-01.dmp
Crash Time : 4/1/2020 9:17:04 AM
Parameter 3 : ffff9b0f`8419d680
Parameter 4 : ffffd589`7e0378e0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\040120-36281-01.dmp
Major Version : 15
Dump File Size : 1,056,496
Dump File Time : 4/1/2020 9:18:20 AM
Dump File : 032620-37328-01.dmp
Crash Time : 3/26/2020 9:21:03 PM
Parameter 3 : ffffa685`de678040
Parameter 4 : fffff804`16c6b8e0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\032620-37328-01.dmp
Major Version : 15
Dump File Size : 1,061,646
Dump File Time : 3/26/2020 9:22:19 PM
Dump File : 031920-40187-01.dmp
Crash Time : 3/19/2020 10:20:50 PM
Parameter 3 : ffffc809`6e3f5380
Parameter 4 : fffff804`41a6b8e0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\031920-40187-01.dmp
Major Version : 15
Dump File Size : 1,181,192
Dump File Time : 3/19/2020 10:22:07 PM
Dump File : 022820-49812-01.dmp
Crash Time : 2/28/2020 10:23:49 PM
Parameter 3 : ffffb503`1aa185c0
Parameter 4 : ffff9786`3a23ec30
Caused By Address : ntoskrnl.exe+1c1510
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+1c1510
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\022820-49812-01.dmp
Major Version : 15
Dump File Size : 1,181,072
Dump File Time : 2/28/2020 10:25:12 PM
Dump File : 022620-35671-01.dmp
Crash Time : 2/26/2020 11:04:56 AM
Parameter 3 : ffffbd07`09f90040
Parameter 4 : ffffcd0c`d6a378e0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\022620-35671-01.dmp
Major Version : 15
Dump File Size : 1,135,360
Dump File Time : 2/26/2020 11:06:13 AM
Dump File : 022320-35781-01.dmp
Crash Time : 2/23/2020 10:29:56 PM
Parameter 3 : ffff8f05`55e31680
Parameter 4 : fffff804`0a66b8e0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\022320-35781-01.dmp
Major Version : 15
Dump File Size : 1,011,048
Dump File Time : 2/23/2020 10:31:10 PM
Dump File : 021220-44203-01.dmp
Crash Time : 2/12/2020 10:03:47 PM
Parameter 3 : ffffad83`d9221040
Parameter 4 : ffffea84`f38298e0
Caused By Address : ntoskrnl.exe+1c14e0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+1c14e0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\021220-44203-01.dmp
Major Version : 15
Dump File Size : 1,078,800
Dump File Time : 2/12/2020 10:05:09 PM
Dump File : 021020-37546-01.dmp
Crash Time : 2/10/2020 8:55:13 PM
Parameter 3 : ffff8101`2e2f0040
Parameter 4 : fffff802`6ee6b8e0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\021020-37546-01.dmp
Major Version : 15
Dump File Size : 1,078,016
Dump File Time : 2/10/2020 8:56:28 PM
Dump File : 020720-35515-01.dmp
Crash Time : 2/7/2020 7:28:56 PM
Parameter 3 : ffff8685`cf4b9040
Parameter 4 : fffff803`1d26b8e0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\020720-35515-01.dmp
Major Version : 15
Dump File Size : 1,096,392
Dump File Time : 2/7/2020 7:30:12 PM
Dump File : 013120-35546-01.dmp
Crash Time : 1/31/2020 11:08:16 PM
Parameter 3 : ffffc18f`eb267040
Parameter 4 : ffffeb0c`2f4378e0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\013120-35546-01.dmp
Major Version : 15
Dump File Size : 978,460
Dump File Time : 1/31/2020 11:09:30 PM
It does look like your bluescreens starting from May 10th are being caused by the latest install of Malwarebytes. What version did you install? 4.10 is that latest. I would suggest redownloading malwarebytes again here.
https://www.malwarebytes.com/mwb-download/thankyou/
Please uninstall the current version first though, then reboot then try installing again.
Thanks. I uninstalled Malwarebytes and rebooted. I had Ver 4.1.0.56, but I'm going to wait awhile before reinstalling it to see if I still have any problems. The one thing I noticed right away is that BitDefender loaded right up whereas it was taking up to 15 min to load.
It was probably just a corrupt install. Let us know if you decide to reinstall and if the issue arises again.
There you see! Malwarebytes was the culprit..
Many years ago malwarebytes was good to use.. Nowdays it aint..
I suggest that you do NOT reinstall it.. If you like a "second opinion" scanner try Hitman Pro (free) or https://www.sophos.com/en-us/products/free-tools/virus-removal-tool.aspx
I've installed malwarebytes on hundreds of machines and not one single issue. Just because there is an issue on one single machine here on the forum doesn't mean its a bad product. I want to see you fight with all the malware removal experts that malwarebytes isn't a good program to use.
My computer is running pretty good right now and I even left it on the whole time without it crashing so I'm going to run it like this for at least a week or so before I do anything else.
As I told earlier, Malwarebytes WAS good, Nowdays its not as good as it used to be..
Take a look at a endurance test windows-rescue-after-a-virus-attack done by av-test.org at: https://www.av-test.org/fileadmin/_...9_Repair_1bis1218_SW_Einzel_EN_7e670cb394.jpg
There you will se for your self that it´s only malwarebytes and Windows defender that MISSES to detect malware, and these are among the list of those who LEFT ACTIVE MALWARE REMNANTS in the computer... (Since you do not seem to get it.. They actually left the computer with ACTIVE MALWARE LEFT EFTER ITS DONE!!
But something tells me that is still good, in your eyes.. (Not in mine!) (full test here: https://www.av-test.org/en/news/endurance-test-windows-rescue-after-a-virus-attack/ )
so you had bit defender and mwb running at the same time?im thinking there was a conflict there. i know i had conflicts with mwb and avast.i only run one av program for this reason,and its malwarebytes.
