farmerjohn1324
Anyone using Immunet?
Is there a way to do this AFTER it's been installed? I've used it for some time, am relatively happy with it, but just wanted to check.I use it and think its one of the better ones. Just make sure you choose to do a custom install and only check the first 3 boxes on the left.
Holy necro-bump....Is there a way to do this AFTER it's been installed? I've used it for some time, am relatively happy with it, but just wanted to check.
thanks for all you (and others) do
You can actually go into control panel, programs and features and highlight avast and click on the change button. Follow the prompts and it will allow you to modify the install to only choose those 3 options.Is there a way to do this AFTER it's been installed? I've used it for some time, am relatively happy with it, but just wanted to check.
