PC upgrade to R5 3600
bbrano123
Hi, I would like to know what do you say on upgrade of my budget pc
PC case - Lenovo ThinkCentre M29p
Mobo - Lenovo MAHOBAY
Intel i5 3570
GPU - AMD RX 570 4GB
8GB RAM DDR3
SilentiumPC 450W
1TB HDD od WD
To :
Mobo - ASRock B450M Pro4
CPU - AMD Ryzen 5 3600
GPU - I will keep my 570 for now cause i think its still not a bad card
RAM - Patriot Viper Steel Series 16 GB KIT DDR4 3200 MHz
PSU - Gigabyte P650b
1TB HDD from WD
Crucial MX500 500gb SSD
PC case I haven´t choosen one yet, but if you know some good cheap case under 50€ you can let me know.
Thanks for you opinions and advices. :)
Seems decent bro should be significantly faster than that i5.
Thank you and yeah it should be. The case I´m probably gonna buy is Zalman Z1 Neo. But I´m still not sure what motherboard to choose. Is it worth to spend a little more and buy an ASRock B450 Pro4 (the ATX one) ? Or do you have other ideas?
Be careful of using any AMD series 400 motherboard chipset and Ryzen 3rd gen CPUs.
Some AMD B450 chipset motherboards may need a BIOS update prior to using Matisse CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revision - this link explains.
Unable to Boot New Desktop System Configured with AMD 3rd Generation Ryzen™ Desktop Processor, and AMD Socket AM4 400-Series Motherboard
Another user on this forum has run into exactly this problem
Consider either of the following which do not require CPU to update BIOS:
MSI B450 Tomahawk
MSI B450 Gaming Pro Carbon or any of the gigabyte b450 mobos that have Q-flash plus technology.
MSI B450 Tomahawk
Yeah I read about that some older mb's do need a BIOS update but I found that this asrock mb is now manufactured with BIOS version that's "AMD 3000 ready" so no need to update but even if I had to I would manage to update that bios. But thanks for your warning and advice.
MSI B450 Tomahawk
Yeah, I had that problem with my Tomahawk going to a 3600
Thankfully you can flash the bios using a usb stick on a port on the back but still a bit of a pain
