Should I turn off Windows write-cache buffer flushing on my SSD?
Should Windows write-cache buffer flushing be turned off?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 1 100.0%
  • Total voters
    1
20886432
Also, should I keep the "Enable write caching on the device (the SSD)" checked like it is by default?
Generally the default options are the default for a reason. The dialog for them is pretty self explanatory too.
Leave stuff alone. Are you having some perceived issues with your SSD or just trying to maximize performance?
Back when I regularly used a guide for installing Windows on an SSD they note you should turn it off to reduce wear on the drive. But a normal drive will outlive you so no real reason to.
