Unusual dual monitor display/Video situation -
Da Mail Man
Unusual display/Video situation -
1)...I use the older Windows XP Pro and use two monitors.
2)...I have the display(s) set to use "monitor 1" as my "primary desktop" (task-bar at bottom, etc).
3)...I have the display(s) set to use "monitor 2 " as my "extended desktop".
4)...If I play (for example) an mpeg video on "monitor 2 " of the display(s), it will not display the playing video on "monitor 1" , in fact, the video will ONLY play on one of the two monitors and not the other.
5)...While the video (both sound and video) is playing, I can "slide" the video interface (using VLC Player) over from one monitor to the other and, when it gets about 1/2 way, I lose whatever portion of the video that is in the other monitor! The sound is fine but, here is where I start the video display issue.
6)...I can hear the sound portion fine but, no video display when the video i slid over..
Why is that since "monitor 2 is an extended desktop that I should lose the video portion?
Thanks in advance for any reply(ies).
Darren
Moderator
I didn't even know XP supported multiple monitors.
Are you trying to watch the same image across 2 screens or something here or just moving a window back and forth?
Some modern hardware and an operating system that isn't 2 DECADES old is probably a good place to start. Sounds like some limitation of playing live video across multiple screens. Different video player might be worth trying too.
Da Mail Man
I have been using 2 for years.
Just watching on one screen/monitors...I used to do this as recent at mid-late August...If i needed to slide it out of the way, I could with no issues.
No, not a good place to start since I am using the same monitor(s), computer, and graphics card, same player (VLC).
No....I have done this before in fact, back in late July...I reformatted my computer as it was "about time to" and it workED fine. I cannot figure it out.
johnb35
Administrator
Possibly a display driver issue. Or if it was working correctly just recently, you can do a system restore back to when it was working. Or possbily try using a different monitor to make sure its not a monitor issue.
Da Mail Man
I have considered that. To be honest, I am NOT sure if the driver I am using was/is the same one I used before....I am already contemplating searching for another driver.
No, not possible...I did a total re-format, remember?...I was using a single monitor up to the other day while I was transferring/loading files back onto my reformatted computer so, no restore point exist where a dual monitor setup was operating.
Already did that so that they were not suspect.
johnb35
Administrator
Go into device manager, expand the display adapter section and take a screenshot of it and post it here.
So are you saying it wasn't working correctly after the reformat?
Da Mail Man
ASAP - will do.
No, what I said was all was working until I reformatted the HD. I did not save the installed drivers. But, it DID work - no hardware changes just, as aforementioned, possible incorrect driver is all I have left to try.
beers
Moderator
'It doesn't work but it used to' is entirely different than 'I reformatted and it doesn't work anymore'. That's the kind of information that needs to be included up front.
Clearly a software issue between drivers/config. John was hoping you'd post Device Manager to see the ones you didn't install drivers for. The generic Windows driver is pretty terrible in most instances when you're trying to leverage accelerated workloads.
ASAP - will do.
You could have grabbed this in 10 seconds by Win+R -> devmgmt.msc -> Alt+Printscreen on the Device Manager window -> Paste into the reply box here.
Da Mail Man
I believe I presented that and was "up-front". EVERYTHING worked BEFORE I reformatted. When I reformatted I did not save drivers. When I reinstalled everything, that is when the issue arouse. Not being sure of driver could be it as was stared and as I agreed.
Very well could be.
Yes, I know that and will do that soonest but, involved in something a bit more critical now and most of my attention is diverted to that!
I was and did not use the Windows driver.
Like I said I will post ASAP.
Thanks for the reply(ies)
Da Mail Man
Sheesh I remember my GeForce 3 being faster than that card literally 20 years ago.
Not relevant to my situation here. I am working with my hardware, not the hardware others think I should have (respectfully),
Why do you never upgrade?
Personal choice and preference. It worked once and should work again.
Try this guy
CORRECTION - I jumped to conclusions - I thought the site/link was to a driver site NOT of the manufacturer...sorry...will try it.
Da Mail Man
Yeah, thats an old driver. Notice how it says Dell at the end? That means the driver was provided by Dell and not by Nvidia and they usually don't list updated video drivers for cards that old. Try the driver Beers listed and if it don't work then not sure what to tell you.
yes, but was working IF it was the same driver I used before. I went on the dell site and it did not recognize the model and tag of my desktop.
yes, i do
Leerie about using "driver sites" as I heard they may contain malware.
*THANKS FOR THE REPLY(IES).
johnb35
Administrator
Thats not a generic driver site, its straight from manufacturer Nvidia which makes the chip on the video card you are using. We don't link drivers from places like that, always from the manufacturer.
Da Mail Man
I just got done correcting my statement just as your reply came in seconds ago...I will try it soonest.
Da Mail Man
I just attempted to do a download and on all visible links got the following:
"The page cannot be displayed because an internal server error has occurred".
beers
Moderator
Debatable my dude, it’s all related. Newer equipment works more seamlessly out of the box, you wouldn’t have the same issue on an igpu from the last decade or so.
Hopefully that driver from 15 years ago works better for you.
Try this link instead:
Da Mail Man
Well, all I can say all worked with what I was/am using and so, should work again.
**UPDATE**
Last night I fooled around with all the settings and dl'ed another driver from some obscure place and, after fooling around with all - IT WORKS!...I have no idea as to what I did and not sure if it was another driver that did it or, at least in part contributed to the fix..
**I would like to take this opportunity to again thank all those whom contributed their responses and time**.
