VPN recos? Aside from ExpressVPN.
theitaliansauce
So I've been using ExpressVPN for a while because of the nature of my work. I work at an email marketing agency focused solely on Klaviyo but more on the technical side so I use VPN often to check our work (aka coded email templates).
I was wondering what other VPN can you recommend aside from ExpressVPN? Don't get me wrong, it's great, it's fast but what I don't like about it is the changing IPs every time you connect.
I heard great stuff about Nord with regards to having a dedicated IP but I find Nord slow. I did their trial before.
So any recos?
beers
Moderator
Isn't that the entire point of using the VPN for your use case? In a shared pool environment you'll rarely be seen as the same address.
Not sure that I would pipe anything work related through a third party implementation.
theitaliansauce
Thing is though, the IP address that's being used has a lot of traffic and that usually gets tagged as "an unusual amount of traffic". I reckon, a lot of the VPN IPs available via ExpressVPN gets marked or banned for some reason in different sites.
beers
Moderator
Might be more effective to roll your own tunneling implementation to the remote host of your choice.
