"Why don't you just buy some decent invoicing software, I'm thinking it would make your job a hell
of a lot easier". "But I still suggest you find an actual coding forum to help you."
John, I assumed, from the name Computer Forums that you were an actual coding forum and as a web
developer myself have been using your staff myelf for years. This is an actual property management
system that has been in use for over 10 years. I occasionally update and upgrade using various
forums to help. I've kept coming back here for some time with the same question re. the echo not
working. As many times as John has seen these posts he's not offered the answer. You're right, I
will start using a more knowledgeable forum.
