Thanks John!
It’s strange; my daughter comp is much older and slower, not close capable as mine and she upgrade to W11 with no problem.
Now, my W10 works perfect and just wandering if I need that 11 at all. What you think?
Also if I somehow manage to upgrade will be my files, programs etc. remain or I could list them?
Windows 11 is fine too. The TPM nonsense is bollocks and can be integrated or simply ignored. Multiple methods to do both.
You could also dual boot, try out 11, and either delete 10 later and expand your 11 partition, or the revert back to 10 and expand that partition.
Dual booting is super easy these days, particularly between 11 and 10. You're be presented with a menu upon start up, or your can enable a default choice.
Either way, this whole talk about windows 10 is fine, and true, but it also happens EVERY time a new OS comes out. Some on here still hold on tight to 7.
