Hi, a little help, please. I have been using:
<tr bgcolor="#D4AAFF">
<td><input name="radiobutton" type="radio"
value="http://target.com" onclick="gotolink()">target name</td>
<td>purpose for target</td>
<td>username " "</td>
<td>password " "</td>
<td>secure?/ans " "</td>
<td>emailused " "</td>
<td>0000-00-00</td>
<td>22</td>
<td></td>
<td>Y</td>
in an html program to keep show passwords, click on the button and go to the url.
This BELOW code selects a record from a database table and updates the date visited and times visited.
I want to use the onclick here to go to the url also.
the code:
<!DOCTYPE><html><head><title>email menu</title></head>
<body><center>
<form name="form" method="post" action="">
<?php
$con=mysqli_connect("localhost","root","","homedb");
//============== check connection
if(mysqli_errno($con))
{echo "Can't Connect to mySQL:".mysqli_connect_error();}
else
{echo "Connected to mySQL</br>";}
//This creates the drop down box
echo "<select name= 'target'>";
echo '<option value="">'.'--- Select email account ---'.'</option>';
$query = mysqli_query($con,"SELECT target FROM lookuptbl");
$query_display = mysqli_query($con,"SELECT * FROM lookuptbl");
while($row=mysqli_fetch_array($query))
{echo "<option value='". $row['target']."'>".$row['target']
.'</option>';}
echo '</select>';
<p><p>
<CENTER>then
<input type="submit" name="submit" value="Submit"/>
</form></body></html>
<!DOCTYPE><html><head></head>
<body><center>
<?php
if(isset($_POST['target']))
$name = $_POST['target'];
$fetch="SELECT id, target, username, password, purpose, emailused,lastused,
visitcount, saved FROM lookuptbl WHERE target = '".$name."'";
$result = mysqli_query($con,$fetch);
if(!$result)
{echo "Error:".(mysqli_error($con));}
//display the table
// echo '<table border="1">'.'<tr>'.'<td bgcolor="#ccffff align="center">'. 'Email menu'. '</td>'.'</tr>';
echo '<tr>'.'<td>'.'<table border="1">'.'<tr>'.'
<td bgcolor="#CFB53B align="center">'.'id'.'</td>'.'
<td bgcolor="#CFB53B align="center">'.'target'.'</td>'.'
<td bgcolor="#ccffff align="center">'.'username'.'</td>'.'
<td bgcolor="#ccffff align="center">'.'password'.'</td>'.'
<td bgcolor="#ccffff align="center">'.'purpose'. '</td>'.'
<td bgcolor="#ccffff align="center">'.'emailused'.'</td>'.'
<td bgcolor="#CFB53B align="center">'.'lastused'.'</td>'.'
<td bgcolor="#CFB53B align="center">'.'visitcount'. '</td>'.'
<td bgcolor="#CFB53B align="center">'.'saved' .'</td>'.'</tr>';
while($data=mysqli_fetch_row($result))
{echo ("<tr><td>$data[0]</td><td>$data[1]</td><td>$data[2]</td><td>$data[3]</td>
<td>$data[4]</td><td>$data[5]</td><td>$data[6]</td><td>$data[7]</td><td>$data[8]</td>
</tr>");}
echo '</table>'.'</td>'.'</tr>'.'</table>';
$target='target';
$visitcount='visitcount';
$lastused='lastused';
$saved='saved';
$sql = "UPDATE lookuptbl SET visitcount=$visitcount + 1, lastused=NOW() ,
saved='$saved'
WHERE target='$target'";
if ($con->query($sql) === TRUE) { echo "Record updated successfully"; }
else { echo "Error updating record: " . $con->error; }
$con->close();
</body></html>
Thanks in advance for response!
<td>0000-00-00</td>
<td>22</td>
<td></td>
<td>Y</td>
the code:
<body><center>
<?php
else
.'</option>';}
echo '</select>';
<p><p>
<CENTER>then
<body><center>
<?php
if(!$result)
//display the table
</tr>");}
$target='target';
$saved='saved';
saved='$saved'
$con->close();
</body></html>
