The most budget motherboard
alij2021
Hi,
What are some motherboards below $200 out there which support 13th Intel generation CPU and DDR? It should be m-ATX.
Also, are you aware any upcoming budget DDR5 and 13th Intel CPU motherboards?
Thanks
johnb35
Administrator
There are all kinds but since you are in a different country, not sure what your price would be. Availability and price will always be different from what we have here in the USA.
johnb35
Administrator
As I said, availability is gonna be different. You can search for it easier than I can since I have no idea what online retailers you can use. Look at the online retailers that can deliver to you. Filter by slot 1700 then matx form factor then by price.
beers
Moderator
It does not matter. I need models.
It matters though since a different market could push a certain model above $200 depending on which market you're in.
Plenty of Z690 boards in your range though which also support 13th gen just pick what you'd like. I assume you'd stay DDR4 due to cost.
Z790 push it up closer to/at $200 though.
