This is an issue with a specific program I use at work (Sage). The program opens fine, but when I open another window inside that application (or opening a third), It opens the window on a non-existent monitor. It happens consistently when I disconnect external monitors (take my laptop home). Sometimes it happens when external monitors are plugged in. I have to open the laptop or unplug then replug monitors to get the window to appear. When I hover over the tab at the bottom, I see there''s an aditional window open, but I cannot get it to pop up on a display. This is apparently a known issue with the program, but there's no fix for it (so I'm told). Is there a way to force Windows to open new windows on the screen that the cursor is currently on?
One fix that I've found that works occasionally is to get the window open, open the laptop, drag the window to the laptop screen, disconect external monitors. This works maybe 50% of the time, but once the problem returns, I have to plug back into my monitors.
