wizlinkx
Hello guys,
I'm new here.
I hope the explanation about my issue is clearly stated
and someone can shed some light on this.
I'm trying to connect a Mid 2014 MacBook Pro running macOS Big Sur with an HP ZBOOK G4 running Windows 11 Pro, for file sharing across my home LAN.
I have set up both for file sharing and they work fine via wifi.
Both are connected to a WiFi router, a D-Link model DIR-853/ET. Not connecting to the internet thru this.
The Mac is connected to the router via wifi while The ZBOOK is connected via an ethernet cable and WiFi.
But WiFi is disabled in the ZBOOK when I don't need it, which I will shortly explain.
I'm assuming all features on the router work as they should because it is only 3 months old and has been working well.
The router is configured for DHCP, and the subnet masks are identical.
Accordingly, 192.168.0.x 255.255.255.0
File transfers between them are ok using wifi.
Here's the issue.
I have a small home broadcast studio and use the ZBOOK to connect and control a Blackmagic ATEM Mini Pro video switcher.
The ATEM has USB type-C and ethernet ports.
Ethernet is the only way to control the ATEM using Blackmagic's Control Software.
The ATEM streams Video/Audio via the USB type-C port.
That is connected to the ZBOOK's USB type-C port, which I use as a live input to OBS for broadcasting.
Content files I create on the MAC need to transfer to the ZBOOK on the fly.
Since the Mac can only connect via WiFi to the router ZBOOK ethernet cannot see the Mac.
So this is to say that I can't see the Mac on Windows Explorer 'Network' when connected through ethernet.
I should be able to do the file transfers without having to switch the WiFi adapter on and off on the ZBOOK every time.
The ethernet connection between the ZBOOK and the ATEM via the router is in perfect working order.
I cannot understand why the internal routing between the ethernet ports and the wifi isn't working in the router.
I appreciate your help on this.
Thank you guys in advance.
I'm new here.
Here's the issue.
