Hi,
I'm putting together a small 15-liter PC from old parts and a Packard Bell mini ITX case. I managed to install Windows 10 and a few Adobe programs, but now it shuts down very quickly. It could be within a minute or less.
Initially, I thought the problem was the fan at the back; I had installed it the wrong way around, so it was blowing in instead of out. But now I have turned it around.
I think the issue started when I tried to secure the cooler better on the processor. It was loose at first because the brackets weren't the right ones, so I tried tightening it with small zip ties. Could it be that it’s poorly seated and getting overheated?
I’ve tried reinstalling Windows, but it doesn’t get far before it shuts down again. How should I best troubleshoot this?
Specs for the PC:
Specs for the PC:
- Motherboard: AMD ASROCK FM2A85X-ITX
- CPU: AMD A10-6800K CPU A10-Series Quad-Core 4.1GHz 4M 100W Socket FM2
- RAM: HyperX Savage 16GB (2x8GB) / 2400MHz / DDR3 / CL11 / HX324C11SRK2/16
- PSU: SilverStone 450w SFX form
- Fans: Front Corsair 120mm, rear Noctua NF-A6x25 PWM 60mm, AMD CPU cooler
- GPU: None yet, 240mm slot available
