Buying New Desktop
Root Seeker
I’m looking to purchase a new desktop computer for genealogical research. I would like assistance determining a suitable off the shelf desktop. It needs to be fast, have lots of storage, handle graphic charts, have reliable connectivity and be expandable. Thank you for any help, it’s much appreciated.
Hi Root Seeker!
If you want something that feels fast today and doesn’t become limiting in a couple of years, you should focus less on “brand” and more on the right components. Genealogical research isn’t just browsing—it often involves large databases, scanned archives, image processing, and chart generation—so balanced performance matters.
Here’s what I would recommend for an off-the-shelf desktop:
CPU (Processor)​
Go for a modern multi-core CPU:
  • Intel Core i7 (13th gen or newer)
  • or AMD Ryzen 7 (7000 series or newer)
This ensures smooth performance when working with large family trees, multiple apps, and browser tabs.
RAM (Memory)​
  • Minimum: 16 GB
  • Recommended: 32 GB
Genealogy software, browsers, and image tools can easily consume memory—more RAM = smoother multitasking.
Storage​
You specifically mentioned “lots of storage”—this is key.
Ideal setup:
  • 1 TB NVMe SSD (for system + programs → speed)
  • 2–4 TB HDD or SSD (for archives, scans, backups)
If your research includes many scanned documents/photos, storage fills up quickly.
Graphics​
You don’t need a high-end GPU, but:
  • Integrated graphics (AMD/Intel) is fine
  • Optional: entry-level GPU if you use heavy charting or large displays
The real benefit is smooth rendering on high-resolution monitors.
Connectivity​
Look for:
  • Wi-Fi 6 or 6E
  • Gigabit Ethernet (or better)
  • Plenty of USB ports (USB-C helpful)
  • Optional: Bluetooth for peripherals
Reliable connectivity matters if you sync data or use online archives.
Expandability (very important)​
Avoid ultra-compact PCs.
Look for:
  • Standard ATX or micro-ATX tower
  • Free RAM slots
  • Extra drive bays (2.5” / 3.5”)
  • PCIe slots for future upgrades
This gives you flexibility later.
If you want, tell me:
  • your budget
  • Windows vs Linux preference
  • how large your data sets are
…and I can suggest a very specific model configuration.
If you are going to use ChatGPT / Copilot, then at least change the formatting.
@Root Seeker You may want to look in Dell's Tower Plus Desktop (EBT2250) models and configure to your specifications.
If you can find any XPS 8960 refurbished, then that may be an option too.
Hi Root Seeker!
CPU (Processor)​
RAM (Memory)​
  • Minimum: 16 GB
Storage​
Ideal setup:
Graphics​
Connectivity​
Look for:
  • Wi-Fi 6 or 6E
Look for:
  • Free RAM slots
  • your budget
I want to keep the cost $1K or less if possible. I’m most familiar with Windows so I would prefer it, as far as data sets I have no clue
I have become completely computer illiterate over the years, I’m of the generation of Apple 2. I think I started becoming computer illiterate in the mid 2000s.
Thank you for your input. I was looking at a Dell 8960 a couple of weeks ago but I will look at the Tower Plus as well!
