is liquid coolin worth an extra 50$ or should i stay with a normal fan
You defintily wont need to use the water cooling until you want to overclock. Since it is only $50 I would do it, so when you do want to overclock, you can.
But the $50 water cooling may turn out to be junk. IMO, good air cooling, is better than cheap water cooling.
its not 50$ its 50$s more then air cooling
Even if he meant an additional $50 added to the HSF cost, so lets say a maximum of $100
