One Long and Two Short Beeps
SquishyPoo
I just finished building my computer and I am having problems. When I start up my computer, it starts beeping one long and two short and nothing comes up on the monitor. All the fans are working and I checked if everything is in place. Also, I reseated the ram and video card a couples times, and I tried clearing the CMOS. :mad: :mad: :mad:
OCZ Gold EL PC2-6400 2GB 2X1GB DDR2-800 CL5-5-5-12 240PIN DIMM Dual Channel Memory Kit W/ Ramsink
Antec Sonata II Black ATX 16IN Mid Tower Quiet Case 3X5.25 2X3.5 4X3.5IN 450W Air Duct 120MM Fan
ATI Radeon X1800 XL 256MB 256BIT GDDR3 PCI-E Dual DVI HDTV-OUT Video Card Retail
Liteon SHW-160P6S-05 16X DVD+-RW 4X Dual Layer IDE 2MB Black OEM Burner W/ SW
Seagate Barracuda 7200.10 320GB SATA2 3GB/S 7200RPM 16MB Cache NCQ Hard Drive
AMD Athlon 64 X2 3800+ Dual Core Processor Socket AM2 Windsor 2.0GHZ 2000FSB 2X512KB 90NM Retail Box
ASUS M2N-E ATX AM2 NFORCE570 DDR2 PCI-E16 2PCI-E1 3PCI SATA2 Sound GBLAN Motherboard
i recall one long and two short supposedly is a video error but dunno if thats still the case
anyways
check out this thread on anadtech forums
http://forums.anandtech.com/messageview.cfm?catid=29&threadid=1881790
its seems some people there have had an issue with this board and OCZ memory, something about it not being officially supported, one post in particular caught my eye
Friend has the M2N-E with OCZ DDR2-800 2x1GBsticks and it wouldn't post at first until I got some ddr2-533 memory to put in it and boot it then he was able to manually select ddr2-533 and it will run like that. From his research so far it appears that it is related to the memory not being officially supported ie it doesn't like the SPD timings. Seems as if the Corsair is the only stuff that is working right now. For now he is just running DDR2-533 with no stability issues. Might try downclocking yours to ddr2-533 just to see if the stability issues go away.
I agree, I think it's video related. Try pulling the card, powering up, powering back down, then reseating the card. I've had to do that once before with my system.
