Good Setup? Not sure, Will it work?
lunchboxx
This is my setup im pretty sure it will work but im not %100 so it would help if some of you could tell me the problems or if its all workable.
Case
http://www.newegg.com/Product/Product.asp?Item=N82E16811144034
PSU
Changed to
http://www.newegg.com/Product/Produc...82E16817103931
PCU
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2280511&CatId=2397
HDD
changed to
http://www.newegg.com/Product/Product.asp?Item=N82E16822136003
MOBO
Changed to
http://www.newegg.com/Product/Product.asp?Item=N82E16813121035
Memory
http://www.newegg.com/Product/Product.asp?Item=N82E16820145590
CD DVD drive
SAMSUNG Black 16X DVD-ROM 52X CD-R 32X CD-RW 52X CD-ROM 2M Cache IDE Combo Drive - OEM
Floppy
SAMSUNG Beige Internal Floppy Drive Model SFD321B/LEB - OEM
Video card
Changed to
http://www.newegg.com/Product/Produc...82E16814102007
PCU Cooling
http://www.newegg.com/Product/Product.asp?Item=N82E16835118223
Paste
http://www.newegg.com/Product/Product.asp?Item=N82E16835100007
Total xxxxxx shipped
Thats the whole setup to build my new pc now i just need to know if it will work =\
Thanks
Lunch
Keyboard Mouse And screen
keyboard
http://www.newegg.com/Product/Product.asp?Item=N82E16823184011
Mouse
http://www.newegg.com/Product/Product.asp?Item=N82E16826104178
Screen
http://www.newegg.com/Product/Product.asp?Item=N82E16824254008
Total with ship *****
-I would get a better PSU like an AntecTPII
-Core 2 Duo!! Yay!
-There are better mobos for the price
-Get a SATA Hard Drive
-Memory Looks Good
-Video card is awesome
u could update your memory to the DDR2 800 speed that the mobo supports
also you could wait about a week or so and get the CPU cheaper on Newegg when they get more in stock also dropping teh price
i thought the memory i have listed is ddr2 800? and i wont be buying this computer for another like 10 days im just getting ready =p
Looks nice, but I would make a few changes.
You can save some cash with this GPU.
http://www.newegg.com/Product/Product.asp?Item=N82E16814102007
And I would get this power supply.
http://www.newegg.com/Product/Product.asp?Item=N82E16817103931
kk Thanks
__________________________________________________
Oh and does any1 know if newegg might have the PCU i wana get in about 8 days or time will tell? and when i build this computer and im done will i be able just to pop in the XP cd and install windows?
I would recommend this mobo:
and SATA hdds are faster than IDE so you would be safe with a SATA.
They are? Since when? Not in actual performance during most read/write operations they aren't. You might see a few points in a benchmark, but you will never see it in real world performance.
The only SATA HDD to get if you are looking for increased performance is the WD Raptor at 10,000 RPM. The 150 GB Raptor is available now.
Show me the times... Show me the scores. It is all in your head.. Virtual performance.
You know why? I'll tell you, just in case. A PATA HDD's controller bandwidth is a theoretical 133MB/s peak. A SATA HDD is 150MB/s peak. Both have the same spindle speed, with the exception of the Raptor. The drive can only lift the data and feed the controller so fast. At a speed of 7200 RPM it can not saturate a 133MB/s bus, never mind 150.
Soooo... A harddrive is almost never actually delivering 133MB/s to the system bus, especially during typical read/write operations. This is why the ATA133 HDDs are such a scam. You do not even notice a difference over ATA100.
The only time you might notice a difference is in benchmarks, but benchmarks mean absolutely nothing unless you need a little bit of phallic compensation.
