cant find good fan&heatsink for core duo?
You want one with a fan. Only time you want no fan is if you are watercooling.
Remember, the larger the fan, the lower the noise will be at the same cooling rate as a smaller fan. A smaller 80mm fan will make more noise cooling the same as a similar 92mm or 120mm fan. I'd vote the Zalman as well, personally. I will likely buy it for my next system. It will allow quite good OC as well.
Is there any performance difference in between one with fan and one w/o fan?
Usually the ones without a fan on that website requires a fan to run. Ofcourse, you can try running it without a fan and see if the temperature holds, though it probably won't if you have a high powered processor.
