Games on this pc???
Nini
ok since im really a non game oriented person could any of u tell me if my sibling's computer can run any newer games since they want to use it to play on. i have no idea what newer games expect. any help?
here are the specs
Microsoft Windows XP Media Center 2005
Microsoft Service Pack 2
Athlon 64 3700+ 2.2 GHz
*2000 MT/s (Mega Transfers/second)
*Socket 939
ATI Radeon XPress 200
Motherboard
* Manufacturer: MSI
*Motherboard Name: MS-7184
*HP/Compaq motherboard name: AmethystM-GL6E
Memory:
1 GB (2 x 512)
Speed supported: PC3200 MB/sec
Type: 184 pin, DDR SDRAM
Hard drive
*200 GB
*7200 rpm
The hardwares there should easily handle even some resource demanding games without too much problem. I'm sure most of the newer games for kids will run there without need for any hardware changes. I run some machine pounders here with an AMD64 3500+ 2.2ghz without problem. I was running a pair of 512mb PC3200 dimms on the old board until replaced with 2gb of value ram now used for gaming on a new build. If you see problems(not likely) simply get back here.
ATI CrossFire_ Xpress 3200 is the fastest single chip 2x16 PCI Express® platform for AMD AM2 ... range of Intel® processors...more >> Radeon Xpress 200 Series for AMD Processors ... http://www.ati.com/products/integrated.html
The Next Generation Chipset with PCI Express® Graphics built for AMD Platforms
ATI introduces the next generation PCI Express® chipset with Radeon® graphics for the complete range of AMD Athlon™ 64, AMD Athlon™ 64 FX, and AMD Sempron™ processors. The Radeon® Xpress 200 brings both stunning 3D graphics and universal connectivity in a chipset design that provides exceptional value for the high performance. The new chipset can effortlessly scale from everyday multimedia applications to high-definition 3D gaming. The Radeon® Xpress 200 is the first chipset solution in the market with a DirectX™ 9.0 graphics core that is a derivative of Radeon® X300. http://www.ati.com/products/radeonxpress200/index.html
sooo..what graphics card?? You gotta have one for gaming..
You should have asked if onboard video or a PCI-Express card was being used. There are number NVidia and ATI 128mb cards out if one is needed in the event onboard video is being used. The question was raised due to that item not being seen in your signature.
I agree. Integrated graphics pretty much takes running 3d apps and games out of the question. If you don't game, then i guess its fine.
thats basically the specs of my laptop and it will struggle with doom3 bf2 and newer.
ive seem them play bf2 on it . doesnt seem to have much of a problem with it
dont know about the other tho
A laptop doesn't have quite the power demand for graphics a desktop model would. A laptop has a self contained lcd monitor matched for the video and board in it. When you run games and large on a desktop(custom of course) you have to add display power into the equation to see performance on an external monitor. At least 128mb of video ram is needed for the games that have more demand for graphics support. The less intense games get by with a minimum of 64mb especially the older ones.
