ChrisUlrich
Is DDR2 dominant in everyway as far as performance goes?
DDR2 memory is obviously a faster type of memory and runs at higher frequencies like 533mhz, 667mhz, 800mhz, etc.. What helps with speeding up DDR400 is the faster Hypertransport seen with the faster front side bus there. The newer model boards running DDR2 are sure to see better performance as far as memory speed goes.
Is it a huge difference you think? Going from the DDR400 with Hypertransport to the DDR800?
[-0MEGA-];403261 said:DDR400 doesn't have Hyper-Transport, only the newer AMD CPU's do, i think you're getting them mixed up.
"Supported CPUCPU Socket TypeSocket 939CPU TypeAthlon 64 FX/Athlon 64/SempronFSB1000MHz Hyper Transport (2000 MT/s)"
http://www.newegg.com/Product/Product.asp?Item=N82E16813131517
Those are part of the specifications on the Socket 939 model board run here with DDR400 memory.
[-0MEGA-];403329 said:![]()
There is no such thing as Hyper-Transport memory. What you showed me was a list of compatible CPU's for a motherboard.
Apparently you don't read too well. [Originally posted by PCeye] "speeding up DDR400 is the faster Hypertransport seen with the faster front side bus there."
I've only seen the two compared in benchmarks and MHz for MHz, DDR2 is not in any way faster than DDR. I overclocked my DDR and CPU just to see what would happen, and I found that I came very close to the same speeds as DDR2 with the same clock. I have heard many other people say the same thing.
It was hard to resist being glib and titling this article, "Much Ado about Very Little". That feeling of disappointment comes from seeing so much new technology introduced all at once, and then finding out the real performance benefit is extremely small - if it exists at all. If Intel wants us to turn our computer world upside down, there should be a real tangible benefit to the bucks we are expected to spend. Unfortunately, that performance advantage is pretty hard to find - at least for now. There are certainly a few gems in the total package, but if you're looking for a big performance advantage it just isn't there.
[-0MEGA-];403673 said:Are you saying you overclocked DDR400 to say, DDR2-800 speeds? I doubt it.
The reason that DDR2 isnt as great as it sounds, is because it has much higher latancies, which "counteract" with the fast speed, so the performance gain isnt as much.
It depends on the speed. Obviously DDR2-800 isnt going to have a CL of 2 or 3, but you may be able to find some DDR2-533 or 667 with CL's of 3.Do low latency DDR2 chips exist?
[-0MEGA-];403854 said:It depends on the speed. Obviously DDR2-800 isnt going to have a CL of 2 or 3, but you may be able to find some DDR2-533 or 667 with CL's of 3.
I had DDR2-800 in my previous Intel rig, and I got it lowered to DDR2-700, with a CL of 3.
[-0MEGA-];403902 said:Sometimes its not as described.
For example, the memory I bought was DDR2-800 CL4 (so they said). But in reality, it only runs at CL4 when its running at DDR2-667, when it's running at DDR2-800, it's at CL5. I find it pretty hard to believe they could get it at CL3 @ DDR2-800. Unless of course the voltage is insanly high.
