Final draft, look okay?
Everything looks great.
Except the hard drive, which doesn't go anywhere.
For a lower card, 7600GT is good. But if it is at all possible, it would definitely be best to stay with the 7900.
Do you really need a 2ms monitor? You could get a 5 or 6 ms for a little less. Or an 8ms for a lot less.
Get a brand name flat panel. Why must you insist on getting the cheapest, junkiest monitor there is? That's the gateway into your system. That's what you sit there staring at all day. Get a good one. Don't skimp out, or you'll regret it.
For a HDD, if you can afford it get a 150GB Raptor.. Sweetness.
Except for the fact that it's an open box product, that monitor is fine. Rosewill might not make great cases and PSUs but I've never had a problem with mine.
Yeah, too many people make the mistake of spending all their money on hardware and then buying cheap, crappy monitors. Bad idea.
