looking for a laptop...
chooka
im looking for a nice gaming latop...as i have never had a laptop before i dont know anything about their grpahics cards...can someone please help me find a good on for about 1500$ or 1000£ ish. i want the max for my money as i dont want to have to upgrade again in one year... im not fussy about the brand, but 2gb of memory would be nice...
Thanks for any help you can give...
chooka
chooka
Your location please?
I suggest IBM Thinkpad T60. I have been using the T60 for games and all my assignments. I also have a T30, R52 and a X60. All are not good for gaming but the T60 is unique and special. I love thinkpads!!! Thinkpads are a bit expensive but they are very durable and they can last for very long provided you must not abuse it. :)
What does your T60 have in it video and CPU wise?
I have used the T60 for quite sometime and it is good for gaming purposes. I am a heavy gamer and i like a good steady workhorse and after a little messing with a dedicated community specially for thinkpads, i finally decided to get a T60. Many people comment on the T60 and majority said the T60 is very good for gamers.
You didnt answer either of my questions, lol
Do you want to custimize it yourself? If you do, I suggest you try these two sites out. I think they will help you. http://www.ibuypower.com/mall/lobby.htm
http://www.computerforum.com/54979-looking-laptop.html
Oh and [-0MEGA-] I think the t60 has an ati Mobility Fire GL 5200(256MB) graphics card but I can be totaly wrong. And they type of processor I think is an intel dual core 2GHz but I can be totaly wrong and don't take my word for it but I think I am right.
But to really find out, go to www.lenovo.com and then select your country and then select the T60 which I think would be in the notebook section and you will find more info.
Hope this helps
chooka
Here's a great Laptop:
HP nx9420 Notebook PC
This is a computer i am looking at buying idk if u will like it
Intel® Core™ Duo Proc T2050 (1.60GHz/533MHz/2 X 1MB L2 Cache)
1GB Shared Dual Channel DDR2 SDRAM at 533MHz, 2 Dimm
256MB ATI MOBILITY™ RADEON® X1400 HyperMemory™
80GB 5400rpm SATA Hard Drive
its the E1505 from Dell with a battery upgrade, antivirus, and better soundcard i t comes to $1,031.00 usd
or buy a gateway or HP. they are really nice systems. thats all i use and i love them! i play may be 1 or 2 games hear and there and they play fine.
