Overclocking instructions for X1900XT
Master Mind
im looking to overclock my card. but im not sure how to go about it. ive got ATITOOL and AT Tray. i dont want to touch the volts, just the engine and memory clock speeds. can anyone help me out?
thanks
You cant raise the voltage using a program, the only way to do is it do physically voltmod it.
To overclock it, use ATI Tool and raise the Core/Memory speeds. But make sure you are scanning for artifacts while you raise it.
