Hi! i ve changed my broken hard drive on a Toshiba Satellite labtob. A store did it so i guess it was prperly done. At home I ve insert the recovery CD from Toshiba with Window XP. all the process of installation went well . i ve done that several times before and it was exactly the same process i had to go through till i reached the message "remove any cd or floppy and then press any key to continue..."
i pressed any key after having removed the cd... then came the window with the Toshiba logo and the info "press f2 for set up, press f12 foor boot device ctrl" but then came the usual black screen with "WINDOWS XP" and the status bar just under mentionning it s rebooting...and then instead of getting the blue screen asking me to follow the steps of settings the preferences on my computer with the nice little music...the black screen with "WINDOWS XP"
and the status stayed there forever.
i ve redid the entire process like 5 times and it s always the same result. if i simply shut down my compuer and start it again...the same thing happens...the Toshiba logo..then the black screen with "WINDOWS XP"
and the status bar...and that stays there forever, don t reboot... etc...help please
X
