Two questions about Clave Barker's Undying
bigcomp
I guess there was supposed to be some Music while Clave Barker's Undying is being installed.. but i did'nt hear it, is some music there?
Secondly, is there a way to increase game's brightness above the level "brightness = 1" .. coz even if i change this value it resets back to 1..
If you know even any one of them, plz shoot your answer ;)
Change the gamma setting, if I remember correctly the lower the gamma the brighter it is.
Actually it's the higher the gamma, the brighter it is...
And what is this bar that you speak of? Can you move a slider control along it? Or, if your monitor has an auto-adjust feature, it may be able to compensate automatically, and obviously you'd have to do it after you exit as well...
Alright.. to clear it out, heres my situation:
*I keep my monitor at a low brightness level to avoid blowing up my eyes
*Now it works perfectly for windows but incase of games where theres a lot of lightnings, its practically impossible to see so i normally either increase game brightness bar or increase brightness through my video card graphics controller
*As i can't keep on adjusting with the Monitor brightness buttons, above are the best way to do
*But incase of Undying ( & one or two more games ) .. When i adjust brightness through my intel graphics controller, it does increases the desktop resolution ( as usual ) but as soon as i enter the game.. the brightness is'nt effective.. Maybe this engine has some kind of override brightness stuff or something.. So at the desktop i have some kool brightness, but darkness everywhere in the game
*The built-in brightness bar dose'nt provides enough brightness even when its at full
What can be done about it? & don't miss my second question about the Setup Music..
:P
