Navigation for PDA
Kissner
Hey i have a Dell Axim X50V PDA and i would like to put navigation on it. What do i need to buy, where can i get it, and about how much will it cost me?
The X50/51 series has a compact flash slot. CF GPS's would probably be slightly cheaper. As for voice directions, that's obviously all on the software. You might have to purchase some for the voice option.
They may be cheaper, but bluetooth would be much more accurate, since if you're using it in a car, the gpu recevier can be right on the widshield, vs inside the car where the signal isnt as strong.
So if i buy the one that you suggested Omega, will i need to buy anything else or will that be the complete kit to put navigation on my PDA?
