Windows SP2
K3rupt
Is there a Windows XP SP2 Exspecially made for 64bit Processors? or do all sp2's work on 32 AND 64. Or is there a different version For Each. Thx Cya
Windows XP SP2 already is out. Probally the fact i wasen payin attention what section i waz in. I got a new mobo and a AMD 3800+ 64 n was thinken the errors im gettin could be to do with the windows xp sp2 i have installed
Yes, it is out for 32-bit XP. Not 64-bit.
Also, your 2nd post doesn't seem to link up with your 1st one. First, you're asking if there is an x64 XP SP2 release, then your saying that you are having trouble with your 32-bit XP SP2 installation. I don't understand you...
