Urgent!!! Need Last Minute Confirmation
get the nvidia deal where you give you a xfx 7900 gt video card and a ultra x-finity 500w power supply for like 269.98
heres the link http://www.slizone.com/object/slizone_knockout_promo.html
Also corsair ram is very expensive i'd go for the ocz pc-6400 revision 2 platinum edition (224.99)
And keep the same hard drive. But I dunno about the lightscribe drive?? Do you really need the lightscribing ability??
Don't get the KO, it's not worth it. Either go with the deal insaneazian said, or just get the cheapest 7900gt out there. And with the little bit of extra money, see if you can get a soundcard or something, or just save 40 bucks.
And I agree with liuliuboy, you'll want any sound card because intergrated onboard sound is terrible. With the money you saved on the psu and the graphics card might I recommend http://www.newegg.com/Product/Product.asp?Item=N82E16820227139 I also don't understand the deal with the corsair ram and the power supply because the corsair is normally $255 and the hard drive is $67.99 after the rebate which totals $322.99??
Look your video card and psu combine for 359.98
Compared to the deal i linked which offers also a 7900gt card and 500w psu for 269.98, and they are quality pieces of hardware as well.
Also I stated to use the OCZ (2x1GB) Revision 2 Platinum instead of the Corsair which saves you $30 so basically my suggestions basically give you same performance for $100 less
yeah, defineately go with ocz, i have 1gb of theirs, and it's faster than a ferrari.
but for some reason corsair is always like 30$ more for the same range ram... it's like they think that if they raise the price, people will thnk it's more quality and will buy from them instead of other companies
corsair does have high quality RAM and their timings are slighty higher than OCZ
and the 7900GT in the deal isnt as fast at teh eVGA's one
the number at the end of ram is not really that important, the most important numbers are the 1st and 3rd ones. And due your saving $100, isn't that important, I mean it's not like you getting a different video card and firrent wattage of power supply. And the ram is completely similar except for the tras timing which isn't that vital.
ok i see your RAM and all but ive known of CORSAIR to be a good brand and the best for my MOBO
wat i am asking is where am i going to save money if i dont see any 7900gt and PSU combos
