B bradyfan123 New Member Aug 26, 2006 #1 Can someone show me how to use this program?..I've tried burning it on a cd and then running it but it never works, thanks
sup2jzgte New Member Aug 27, 2006 #3 Burgerbob said: You have to use a floppy. Click to expand... there is an Option to use a Cd-r, but I cant get it to work off of a CD, so I just made it off of Floppy, but you can use a CD
Redbull{wings} Active Member Aug 27, 2006 #4 ive used a cd i burned the iso image to it using nero and then booted from cd and it ran fine
red onion Member Aug 27, 2006 #5 You need to download the proper zip file for a CD version, and then burn the ISO as bootable; most progs have problems with this, so it is easiest to use the Feinman Tool then reboot with the CD in and it should run automatically.
B bradyfan123 New Member Aug 28, 2006 #6 wen u say boot you guys mean like restart the computer with the disc in..or start the computer with the disc in?..appreciate the help thanks
Redbull{wings} Active Member Aug 28, 2006 #7 either will work as long as you have your bios set to boot from cd
