Overclocking AMD 64 3400+
I'm not sure what you mean by spikeing :-).. I think of spikeing as when your online and your ping jumps.
Well now that your going to try the 64 bit OS hopefully things will work better for you :-).. Do us a favor and post back and let us know how you like gaming inside the 64 bit windows xp.
I'd imaging it's not going to be an improvement at all but I'll keep my fingers crossed 4 ya.
well im gaming on an x64 opp sys right now and frankly its awsome catch is alot of stuff that should work with x64 doesent for ex. alot of antivirus programs will not install on x64 ez antivirus is the only one i have found and my web cam did not work only creativ web cams will work on x64 at this point in time and logitech has almost no support for x64 (even after nurmous e-mails some rather polite some rather voulger) all i get is well as of right now there are no plans to work on that (F**k u logitech u a bunch of fu** faces) but past that x64 seams to have a huge preformance jump and btw overclocking a 3400+ does make a absalutly amazing diffrence u would be amazed
This thread is over 2 years old...
