knockout34
would two 2ghz dual core xeon processors be that much worse than two 2.66ghz dual core xeons?
It's impossible to obtain 100% effieciency with the two cores, so 2x2GHz Xeons in a dual threaded app does not make the performance of a 4GHz Xeon.fade2green514 said:in dual threaded apps, you get 4ghz out of the 2ghz xeons, and 5.32ghz out of the 2.66ghz xeons. in quad threaded apps you would get about 8ghz out of the 2ghz xeons and 10.64ghz out of the 2.66ghz xeons...
Ever hear of sarcasm?Someone has been posting some erroneous information there. When you combine two NVidia 7900 GTs you don't end up with 15800! That is not how things work when running two video cards in sync with each other on SLI or Crossfire. Those are model numbers not actual performance gains.
well for now, mostly games schoolwork, and internet. down the line i may be doing some video.depends on what you're doing. some applications don't require all the performance two dual core 2.66ghz xeons would offer.
you could look at it this way... in single threaded applications, you get about 2ghz out of the one, and 2.66ghz out of the other. in dual threaded apps, you get 4ghz out of the 2ghz xeons, and 5.32ghz out of the 2.66ghz xeons. in quad threaded apps you would get about 8ghz out of the 2ghz xeons and 10.64ghz out of the 2.66ghz xeons... so ultimately it depends what you're doing, but either way the ratio will be the same. so... say you need to convert multiple videos at one time using all 4 cores. the 2.66ghz setup would give you 2.64ghz faster performance, while in a single threaded app it would only give you .66ghz faster performance. it all depends on how much time you have, if you ask me.
what do you plan on doing with the computer? maybe we can help you decide.
for the average desktop user.. nowould two 2ghz dual core xeon processors be that much worse than two 2.66ghz dual core xeons?
i was indeed joking...lolEver hear of sarcasm?
Unless he was actually serious... I hope not.
We know that! But having two dual cored cpus at 2ghz will usually outperform any pair of single cored cpu setup for the obvious advantage of multitasking on a larger scale. Just imagine two quad cored cpus at the same and compare them to the pair of 2.66ghz Zeons. In that sense you would leave the 2.66ghz setup in the dust. That would be more processing power then a good number of businesses use.
so 2 dual core 2.66 ghz wouldnt make that much of a difference?
here this is what im getting. (it is a total of 3 gb not 2)
http://www.macmall.com/macmall/shop/...ction~view.asp
