Keyboard problem
Shane
Super Moderator
Hi all,
I have a problem with my new Wireless Keyboard.
I cant seem to get the email sighn...this one @,to ever type when i want it to.
I cannot also get any of the moey sighns or the percentage sighn on the keyboard:mad:
The only way i can get it is to copy and paste :mad: which is realy annoying.
Ive tried using my old wired keyboard but that doesnt show em either when i try now.
Any suggestions?
It almost sounds like a motherboard problem... Do you have the wireless keyboard plugged into the PS/2 port or USB?
Yeah i instaled the drivers that came with the Keyboard.
The Keyboard & mouse is Usb but has one of those connectors which makes it into a Ps2 connection.
Aah ive found out whats wrong...There all messed up the number 2 botton does this @ and for some reason the pound sighn does this # lol:D
How can i correct this?
I don't understand, the keys are displaying the capitalized characters without hitting the shift key?
No when i press the shift key and the number 3 above W botton instead of it displaying the pound sighn it displays a # :confused:
There all messed up
In the drive?
Do you mean Drivers?
If so no i cant,It just instals the drivers and theres no other options other than install the drivers.
There all messed up
Umm..., when I press shift+3, I get the # sign too... :confused: That's what you should get...
