Does Vista still have the classic Windows option? Or are you now stuck with the XP type of style in the new version?
The classic theme is still available.
EDIT: I must say they have improved it a lot, its much less buggy and they included some new features. The one I like most is the snipping tool, which allows you to select any area on your screen for a instant screenshot, without having to go to paint.![]()
Is Pre-RC1 a trial? How long is it for?
That's a relief anyways!I was trying out GPart last night to create a vfat primary for a Linux distro on the second drive. How is the installer on it? I imagine it will create or delete and then create a new partition for Windows to go onto. Does it still show the total drive space for manual adjusting the primary partition if you plan to split the drive? XP has it.
You really need a dvd burner though to use it?
[-0MEGA-];417940 said:The ISO is too large for a CD, and it was created for use by CD's.
Im not sure if they will ship CD versions, but most likely it will just be in DVD format.
My key lasts until June 07.
How do I get a key?
