two routers on a network
h34d5h0tz
as the title says, is it possible to use two routers on one network? the second router im trying to use as a switch/hub. i think it will be easier to show a diagram of how i want to set up my network than explain in words:
so, is it possible to set it up how i want to? and if it is, how do i set it up so it functions right? ive tried doing it like that, but i dont get internet to my computers that are connected to the second router.
It's possible with some routers, but some others will try to push their settings out and just conflict with the network... I have managed to do this with a Linksys router as the main one and a Belkin router as the hub/switch. However, if you can just get a switch, that's make things go much more smoothly.
Yeah, most routers tend to play nicer with a switch than a second router. Plus, it's a little cheaper, too :)
