Why would a computer be using 100% of the CPU, even by simply maximizing a window ? o.0 goes from 4% to 100% by just opening a new window.
Windows has one item called the idle process that gives the cpu a task when nothing else is running. This keeps the cpu from running wild and burning itself out from going non stop. Generally you see this at 99% by looking in the processes section of the task manager. When you first open an explorer window you have then given the cpu a new task to perform dropping the idle process down to 0%. Tnen after the window is maximized the idle process kicks back in.
The CPU is a A slot athlon xp running 900 MHz. So yeah, your most likely correct hehe. The guy I am trying to help always bragged about how good his computer was, he said that it can run any computer game with high settings no problem! Is that silliness?
You have to look at the "minimum" system requirements first. Anything above that should see more support for the high settings.
