How to overclock a dell?
Dells don't have the options to overclock the CPU... Man, Intel would be pissed (and don't forget, Intel has a HUGE say...they carve Dell an absolutely amazing deal for chips that noone else can touch).
CPU-E6600 OC to 3.4GHz (assuming you could do so)
RAM-3GB PC800 (3gb = no dual channel, and pc800 is REALLY slow ram)
GPU-nVIDEA GeForce 7950x2 for SLI (doesn't support FSAA and HDR at the same time anyways)
PSU- 700W (lots of wattage, not a lot of amperage.. probly still not enough for 4 video cards)
Sound card-Creative Labs Sound Blaster X-Fi Fatal1ty FPS Sound Card Kit (overpriced and overrated)
MOBO-Asus P5N32-Sli SE Deluxe LGA775/ Core 2 Duo/ nForce4 SLI (overpriced, and overrated)
HDD-4 150GB Raptors in RAID. (overpriced, and overrated.. and which level of RAID btw?)
Custom made Pure copper and pure gold water cooling kit (pure copper, yet pure gold as well? too bad gold isn't as good as copper for heatsinks)
Yeah that's right. You can drool. drool at single channel ram that runs at speeds of less than 800mbps! which of course, therefore bottlenecks the rest of the system... making it total crap :D
Gee, someone likes to critisize...and likes to break down a persons spirit.:rolleyes: And I thought PC800 was 800MHz, to me thats fast. and yes they do make water cooling and heatsink coolers made of pure gold. Just I meant some are pure gold, and others in the system are pure copper. Very expencive. And to make it custom, it would not be a kit. And the MOBO has the ability to use 4GB of RAM. You telling me that PC800 Is not dual cahnnal compadible??? S**T that would suck. I was planning to use those for my next buil. I can get single stick of 1GB for a little over $110.
PC800 is ancient RAM. You are talking about DDR2 800, which is PC6400. The old PC800 could not run in DDR mode, since when it came out, DDR didnt exist.
ADE so take the system out in the sign if you dont have it or put it DREAM MACHINE because your confusing people.And your set up is stuped.Some gold water cooling who cares.And 4 raptors plz.I think you will also need 850 watts for that set up when doing with 4 raptors and 2 7950 and AN OVERCLOCKED CORE 2 DUO with 3 gb.
For me you would waste your money but o well your choice.
