how good of memory should i use to run a game PC6400 or PC8000, it looks like PC6400 (800 mghz) is alot cheaper, is there really that much of a difference though?
Not really, most motherboards use PC6400 (DDR2 800) ram. Anything higher would just downclock itself to PC6400 speed. The only advantage you'll get is when you start to OC.
Or just raise the Memory multiplier to what it should be.![]()
