First Time Power Up --- Something's Wrong --- I'm scared....
returning the ram?
Is it possible?
A few more things I wanna ask you praetor, if u have have the answer:
- Does it matter which slots I have the ram in? At this point I tried them all, but I figured I would put them both in one set... there's 2 sets of 2 each on my MB.
- I just realized that I MAY have accidentally been running the computer for about 20 seconds with a cord preventing the CPU heatsink fan from moving... do u think i may have damaged the CPU like that?
- I have no speakers hooked up to my computer... where would this "beep" come from? The MB????
- Returning the ram is dependent on the store you got it from :)
- If you're troubleshooting, you should only have 1 stick of ram in (i.e., less sticks = less complications). It goes in dimm_1 :)
- Your chip should be ok
- The beep comes from the speaker connected to the mobo
Thx Praetor, I really do appreciate you helping me out.
I guess i'm out to the store tommorrow to buy new RAM.
I hope newegg accepts opened packages.
Well, if it's a small store you might be able to cajole a couple staff to help you out (so long as they arent busy) ... that'll save you some effort ... most stores with technicians willl have spare parts lying around :)
