Hi,
I have an ati all in wonder x1900 and its being a total bitch.
Ive built a new pc but havent had it running because i need the graphics card to run ( no onboard graphics)
neway, i plug it in, the pc powers up but the monitor doesnt pick up anything. two red lights are illuminated on the graphics card one is marked fault and the other power supply. well im presuming the fault is the power supply as I didnt have the additonal pci express power cable plugged into the back of the card.
The thing is the card didnt come with one of these cables and it said in the instruction manual that there wud be one attached to the card if required. Where i bought the card from said an adapter was included for the additonal pci express power (but it wasnt).
So i have gone and bought a 6pin pci express to 2 x 4pin standard power cable. Of the 6 wires that come from the 6pin pci express connector 3 go to each of the 2, 4pin standard power cables resulting in 3 pins on each of the 4pin standard power cables.
http://www.maplin.co.uk/module.aspx?ModuleNo=46857&doy=9m9
I can plug one of the 4pin connectors in but the power supply doesnt like the other one at all.
Ive checked the wires and there not faulty, I also dont think there is a loose connection.
Ive tried connecting the connectors to different connectors and in different arrangements but it just wont work!!
I NEED HELP PLEEEEEASSSE
ati's helpline is always engaged!!
anyhelp would be sooo aprreciated
