liquidshadow
I have a GIgabyte DS3 and a Lian-Li V1000BPlus II case. I screwed on the motherboard but the case screws wouldn't let it be screwed on tight. Anyways, so the motherboard is a bit loose and I can't power up the motherboard unless I kind of pull it away from the motherboard tray. Anyone have this happen? I have to keep pulling it or else it will shut off. I know it's not a part problem because I put together the parts without a case and it worked fine. What is up?
