7300le Vs 6600
Arm_Pit
banned
BFG Tech 6600 128mb(not GT or anything, just 6600)
vs
BFG Tech 7300LE 128MB(up to 256mb with turbocache, but only physicaly 128mb on the card)
Which would be better and by how much? I'm about to leave to go pick up a 7300LE since i need to return my 6600 and need a graphics card untill then, but i might jsut sell my 6600 as new once i get a new one from the manufactor(since it would be new)
I would guess the 7300LE because it has a better GPU compared to the 6600, not to mention it has turbocache, which is a plus.....
And i'm making a suggestion that'll be better,but if you really want...take the 7300LE because its newer and most likely a little better than the standard 6600.
Both are perfectly fine for my needs, well at least the 6600 is, so i would assume the 700LE is. I play games, but i dont need the highest settings with 80fps. I can current play BF2 on high with no AA and keep it above 30fps. To me putting more money into a computer for performace i dont need is pointless, I have the 6600, and im going to have a 7300le regaurdless, just wasn't sure which one to keep. Thank you for the input on the 7300 :)
Well if you have a 6600 then just stick with it, thats a pointless upgrade to the 7300LE.
The explanation is in the first post....
I need to return the 6600 to get a fully working card, and i need something while i wait for one to be shipped back from bfg tech, so im getting the 7300le, and i wasn't sure which one i should keep.
I know, well the 6600 is pretty comparable to a 7300gt so you may lose some performance, if you are wondering which one to keep just bench both of them or google for some comparisons.
I cant bench mark the 6600 since its not working, i would have to do it after i returned it, which by opening the package i would loose the "new" sell value :[
Still don't know why you purchased the 7300le, was it to have a gpu while you returned your old one? It was a waste to go buy another crap gpu, but nvm, that is why I said look on google for benchies.
Yes, i need a card in my computer while i wait for the new card to be shipped to me.
I dont know why you persist on it, I don't need anything stronger then it, I can play the games i like fine, Why would i spend 80$+ on a "good" gpu, when i can spend 25$ on a 7300LE that works fine for me. I could probally sell either for at least that 25$.
Just hold out, your gonna lose money if you just buy another card there is no point. I thought about doing that when I had to rma my video card but decided just to use the family comp for the two weeks or whatever.
I NEED a video card to use my computer while i return the 6600, and I could sell either for the 25$ that the 7300LE costs at frys right now...
Gosh, calm down, just trying to figure out a way where you aren't wasting any money. I would check to see if the 7300le will do everything you need it to, be sure of it, if it does sell the 6600 if it doesn't then keep the 6600 when you get it back.
BTW the 6200LE is the one that is on sale for $25 at Fry's, I don't see a 7300LE on sale.
It's just that i have expalained it over and over again.
I have the advertisment on my desk right now... It's a BFG Tech 3F fusion card 7300LE
Not to mention i bought one, and it said 7300LE on the box.... it just had a 6200 inside, which i dont even know how that would happen during manufactoring.
